Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
Thread: nRoute SKIN for RR and MC2.0
  1. #11
    Constant Bitrate GuMiSZu's Avatar
    Nov 2006
    Hungary
    any response... ?
    Englishlessness :(
  2. #12
    May 2007
    GuMiSZu:
    I tried your nRoute skin, but unfortunately it did not work perfectly for me.
    For example: there were some clicks on wrong tabs in Preferences window.
    You have created some AutoHotKey scripts (they are in exe format) for complex "jobs" to remote nRoute.
    It is a very good idea, but in my case it did not worked perfectly.
    To investigate the problem I decompiled some of the exe files.
    I found mouse movements and clicks in the decompiled scripts, but there were not any tab selection.
    Part of the decompiled U-turns script:
    Code:
    WinWaitActive, Preferences,
    MouseClick, left,  55,  248
    Sleep, 100
    I think it is not always the best way to use Autohotkey macro recorder for this tasks, because it usually uses mouse movements and clicks.
    I have a solution to activate the appropriate Routing tab in Preferences window and uncheck U-Turns box without mouse movements.
    Code:
    SendMessage, 0x130C, 9,, SysTabControl321, Preferences
    Sleep, 100
    Control, Uncheck, , U-Turns, Preferences
    Sleep, 100
    Please try it, think it over, if you need my help please write me.
    I left a message to you on the Hungarian pc2car forum too.
  3. #13
    Nov 2006
    Hungary
    THX!
    ill try it... i use macro recorder to make an exe...
    where can i read the doc of autohotkey?
    YESYES please help me.. i know my """solution""" is very simple and sometimes don't work correctly, but i don't know autohotkey....
    Ducsi akkor ott magyarságosan megbeszélgetjük ok? az jobban megy ))
    Englishlessness :(
  4. #14
    Newbie osa2's Avatar
    Jun 2007
    Belgium
    How do I install the Nroute skin?
    I downloaded the file. I unzipped everything.
    I have put everything in the RR skin dir.
    When I start RR I only see the default skin. Not the one I downloaded.
    What should I change in Nroute?
    I see there is a scripts.zip file. I unzipped that one to.
    Where Do I have to put all the script exe's to?
    How do I tell RR that I would like to have Nroute als deafult gps program
  5. #15
    May 2007
    osa2: I have modified the skin, but it has only a hungarian install file.
    I am going to create an english readme. You will be informed!
  6. #16
    May 2007
    New RELEASE
    I have modified the nRoute skin scripts and the skin commands.
    I have modified the original nRoute_Lang.dll from v2.7.6 to get touch-screen friendly dialogs.
    For example it was the original Find Places window:
    Modified window with better resulution and bigger buttons:
    You can download the nRoute skin from HERE.
    Requirements:
    - RoadRunner
    http://guino.home.insightbb.com/download.html
    Installer with add-ons:
    http://www.mp3car.com/vbulletin/road...r-updater.html
    - MC2.0 skin for RoadRunner, (it is optional, but recommended)
    Release - MC2.0 Skin
    - Garmin nRoute (v2.7.6 it is free, you must use this version)
    http://www8.garmin.com/support/downl...ils.jsp?id=575
    + Garmin maps (not free)
    nRoute skin install steps:
    Step 0. (if you have) completly remove the previous version
    (Delete scripts from c:\!nRoute_SCRIPTZ, delete added lines from rr.ini and ExecTBL.ini, delete skin and jpg files)
    Step 1. Copy the files from nRoute_scripts.zip to your selected RR skin folder
    (for example in case of MC2.0 C:\Program Files\Road Runner\skins\MC2.0\)
    but skip to copy dll files.
    Step 2. Set the followings on GPS tab of RR config:
    - GPS Mode: external
    - GPS Path: C:\Garmin\nRoute\nRoute.exe
    - GPS Window Name: !{5C80D9AE-4379-4cf3-B619-E97D5D1FEADC}
    Step 3.Copy nRoute_Lang_eng.dll file from nRoute_scripts.zip to C:\Garmin\nRoute\ folder
    and rename the original nRoute_Lang.dll to nRoute_Lang.dll.bak
    and rename the modified nRoute_Lang_eng.dll to nRoute_Lang.dll
    About the developers:
    We are from Hungary.
    Original idea and design by GuMiSZu.
    Scripts and modifications by Ducsi.
    Please feel free to comment it!
  7. #17
    Feb 2007
    This is what I was looking for. Just a doubt. How did you modify the original DLL? Do you have the entire project? I would like to do more custom screens. Can you share with us the project? (nroute language dll)
    Thanks!
  8. #18
    May 2007
    I am sorry, I don't have any source files.
    I made my modifications with Resource Hacker.
    Resource Hacker is a freeware utility to view, modify, rename, add, delete and extract resources in 32bit Windows executables and resource files.
    http://www.angusj.com/resourcehacker/
    Just simply open nRoute_Lang.dll with this tool to edit the dialogs.
    I have completly removed the first nag screen....from nRoute.
  9. #19
    Variable Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    Hey ducsi, thanks for the new version of this SKin, I am presently living in Venezuela, and nRoute is the only GPS solution available here. Everything works great, except for 2 things.
    1- The On Screen Keyboard does not work with my touch screen. I have a laptop which I use for testing purposes, and there I can use the On screen keyboard perfectly, I can type in street names, cities, etc. However in the touch screen it does not work, When I want to route to an adress for example, I get the menu (Your edited dll screens) on top and the keyboard on the bottom half of the screen, if I type right away the keyboard works, however if I first click (or touch) the top half of the screen to select the area I wan to type in, (for example I want to type in the city name, or the street name), I click on the area i want to type, and I can see the cursor flashing there waiting for input, I then go and press with my fingers on the keyboard (bottom section of the screen) and i see no text that appears on the top half of the screen where the text should appear, in fact every time I press a key on the keyboard I can hear the Windows "Error Ding", its as if the top half loses focus and the keyboard doesn´t know where to send the output. Any idea how I can fix this problem?? does the On screeen keyboard work for you on your touch screen?
    2- I see you have a back button on the bottom left of the skin, the function of this button is defined in the .skin file and it is presently set to "MAIN" I however want to change the functionality so it actually CLOSES Nroute when I press that button, and not leave it runnin in the background, any idea on how I can achieve this?
    I appreciate your help and look forward to your feedback.
  10. #20
    May 2007
    Hello,
    thanks for the good words and your feedback.
    One of my hungarian friend has a same issue with virtual keyboard.
    I am going to solve the problems in the next few afternoons. (I am currently in the office...)
    Could you please try the followings until my next "patch":
    when you want to type into a field at the top, please don't click there,
    use only TAB key on virtual keyboard to navigate the cursor into the appropiate field.
    About BACK button:
    I does not close the nRoute application, it leaves nroute.exe in the background (winthout window). Please check it with task manager. When you select navigation again it became active.
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. ADSTECH radio skin for MC2.0
    By GuMiSZu in forum RR Skins
    Last Post: 07-16-2007, 10:35 AM
  3. Loaded MC2.0 skin, doesnt work
    By andres2882 in forum Road Runner
    Last Post: 09-27-2006, 04:42 PM
  4. Can someone give me the MC2.0 skin font?
    By Sonicxtacy02 in forum RR Skins
    Last Post: 04-26-2006, 11:51 AM
  5. MC2.0 skin and CDRIp
    By Angelus in forum Road Runner
    Last Post: 01-05-2006, 07:49 PM
