Results 1 to 3 of 3
Thread: need help with flash compass
    Jun 2006
    i have iguidance3 with usb bu-353 and for some reason i can not get flash compass to work if iguidance works if i get flash compass to work then iguidance dont work what can i do to fix this
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    You have to use a com splitter. When you setup your your usb gps unit, it makes a virtual com port. Only one program at a time can access this com port.
    In order for more programs to access the gps data you have to use a com port splitter program .Do a search on xport3 in the gps forum.
    Xport3 will permit you to split the gps com port to two or more virtual comports that will contain the same data as the original. You can then use these additional comports for each program individually.
    The road is long but we are getting there.
    Jun 2006
    thank you tolisn
  1. Replies: 4
    Last Post: 12-04-2008, 02:29 PM
  2. Replies: 33
    Last Post: 03-28-2008, 03:18 PM
  3. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  4. sending keystrokes to flash?
    By Nitrov8 in forum Road Runner
    Last Post: 04-07-2006, 01:51 AM
  5. Replies: 24
    Last Post: 03-03-2006, 01:36 PM
