Results 1 to 9 of 9
Thread: Installing Road Runner on Mac Mini
    May 2007
    Hey everyone,
    Im planning an install, gathering all the programs and setting up everything as we speak so I get a fast and seamless integration in my car. I would like a way to install road runner on my mac, honestly, for me, there isnt enough support for mac's right now to build a carputer that is as useful as using it on a pc. So I would like to run windows on my mac, and was wondering if rr would somehow make me use my itunes, as i spent a lot of time getting everything set up. Also does it matter that Im running a mac, or will it not recongnize my silabs fm tuner and usb gps receiver?
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    As far as getting RR working on a MAC, you only need a program called "BOOTCAMP"...it is a Windows emulator. as far as mounting those devices, i have no idea...you should just need the drivers to mount them on your MAC...
    May 2007
    Quote Originally Posted by rijndael View Post
    thanks for the quick reply. Im a little afraid of running bootcamp, as Im afraid it will cause some slowdown in the computer...
    Apr 2007
    on Earth
    Quote Originally Posted by Vitulla View Post
    it shouldnt slow down your computer, but then again, i dont know your MAC's specs. you can look for benchmarks on some MAC sites im sure...i personally dont know of any since im a PC user...sorry m8...i usually go to tomshardware.com and maximumpc.com for my benchmark reports...
    maybe a google search might help...i found this: http://www.macintouch.com/readerrepo...amp/index.html from a search string "bootcamp emulation possible slowdown" and it was the first result...google is your friend...lol
    May 2007
    Thats why I wanted to just run windows for now until enoughs upport was out for the mini...how do I erase *gasp* Mac OSX, and install xp?
    Apr 2007
    on Earth
    through formatting your harddrive...
    Mar 2006
    NY
    bootcamp is not an emulator, it installs drivers and allows you to modify the bios to accept a full windows partition. Your windows partition will boot up just like any other pc and is very stable.
    The problem I see you having right now is that in order to select my windows partition, I have to hold down option while booting up and select it there. There might be an option to have the windows partiton be the default though. I recommend poking around the apple.com forums for info - I'm sure it's on there somewhere.
    Dec 2006
    I aready use a Mac Mini as a carpc and it is great, Performance is excellent, sound quality is superb, Once you install Bootcamp it becomes the priamry partition and therefore boots straight to XP. If you want to boot OSX then you have to hold the alt key when you push the power button.
    Had acouple of issues getting Radiosark to work, but all other peripherals work fine including the GPS.
    If there is a driver for the device then you load it the same as normal XP.
    you can set your itunes music lib as the default in RR and simply add M4a (I think) and it use your Itunes songs but not itunes. You will need the updated version of Winamp in order to play itunes format.
    Cheers
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Or just the M4a dll files with the older version, as i have done in the past..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Bugbyte's 2001 New Beetle -Mac Mini Install
    By Bugbyte in forum Worklogs
    Last Post: 05-15-2008, 04:31 PM
  2. 2006 PT Cruiser -Mac Mini
    By zapwizard in forum Worklogs
    Last Post: 11-07-2007, 12:54 PM
  3. A Great Idea for the Mac Mini In the car
    By ametalix in forum MacCar
    Last Post: 07-13-2007, 12:11 AM
  4. Road Runner Shell Issue
    By B|ade in forum Road Runner
    Last Post: 05-24-2007, 05:00 AM
  5. road runner freezing on startup :(
    By skiman in forum Road Runner
    Last Post: 03-13-2007, 09:37 AM
