Results 1 to 10 of 13
Thread: Streets 07 GPS enable via skin command?
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    I have S&T 2007 and use the BMV2-esque skin for it in RR. The buttons make opening all the command windows (like GPS) easy. I found a thread containing AutoIt scripts for automatically enabling GPS, centering the map position, and turning on the GPS trail. Is there a way to turn all these on upon hitting the GPS button in the RR skin? Seems like a cleaner solution (and the AutoIt script isn't working for me).
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    i use my own script to launch streets, enable GPS, switch to larger fonts,keep map centered and create a splash screen to avoid seeing my desktop while loading,(the clipping area makes a hole in the skin)also i did some reshack work to streets to make the fonts bigger, and kill the splash screen.in my skin i can switch from ig to streets and google earth.if you want my script i'll share it.
    Feb 2007
    Croydon UK
    st & t
    i don't suppose you have managed to pause winamp when the directions are said from st.
    Nov 2006
    Everett, WA
    I don't use directions (yet). Yes, I'd love that script. Do you just point a button press to an autoit exe file?
    Feb 2006
    Castle Rock, CO
    what about getting the map rotate feature working? if there is a way to get that working i'll get the upgrade to 07. i currantly use mappoint 06
    EL CAMINO's Avatar
    Jul 2005
    ok here it is, honestly i haven't test this yet, in my car i use to use other script, and i come up with this, you can replace the splash.jpg to match you're skin, or if you don't want it. edit the autoit script.
    DOANLOAD HERE
    Nov 2006
    Everett, WA
    I'm working on creating a button script for RR that uses key commands to check all the GPS boxes. It works but I didn't think about hitting the button multiple times to open and close the GPS window. Doh! I'm going to assign the "GPS open and check the boxes" to another button I never use (like the OSK or voice commands) and keep the GPS button operation the same (open and close GPS panel).
    The script is something like this: "...SENDKEY;^a||SENDKEY; ||SENDKEY;{TAB}||SENDKEY;{TAB}||SENDKEY; ||SENDKEY;{TAB}||SENDKEY; "
    It opens the GPS panel, selects "start GPS", tabs to and selects "center map on location", tabs to and selects "create GPS trail". It might not be fully accurate, as I'm doing this from memory. I like this solution better than the AutoIt scripts, which don't seem to work for me anyway.
    Feb 2007
    Croydon UK
    i use a script called keys
    this has been designed around st and ar it does everything mentioned above and more also it will start st or ar when you hit gps button,all you have to do is change the root in rrconfig to start keys first more info here.
    http://www.gpspassion.com/forumsen/t...19&whichpage=1
    Nov 2006
    Everett, WA
    Thanks! That's EXACTLY what I was looking for when I started my quest. I'll give it a try.
    EL CAMINO's Avatar
    Jul 2005
    holly cr@p i was thinking in writing something similar, but forget it, i'll use this, nice find man.
  1. MTK Gps & Streets & Trips?
    By Extide in forum GPS
    Last Post: 03-07-2007, 07:13 PM
  2. Skin command on skin load?
    By jrtf83 in forum RR Skins
    Last Post: 12-07-2006, 04:49 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
  4. Replies: 2
    Last Post: 08-15-2004, 04:49 PM
  5. Anyone understand Java ? I need help.
    By frodobaggins in forum Software & Software Development
    Last Post: 05-24-2004, 10:53 PM
