Results 1 to 6 of 6
Thread: Delete, Current Track.
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    Lightbulb Delete, Current Track.
    for guys with a need to delete a song that for some reason is in your playlist and is not supposed to be there, and even worst Road Runner is playing it.i know hit the "minus1" is an option, but the file is still there, and next time that you load the folder (depending on the skin?) !tara! here we go again.i'm saying all this because i manage to do a workaround to, skip the song, delete it from the playlist, go to explorer, and delete the file manually. i do this from inside Road Runner in a fancy way, based on Sonicsxtacy02's mp3Copy plugin. by the way Thanks again.
    DOWNLOAD
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Here is an easy way to delete a song on the fly....
    Could i get help with a custom delete button?
    EL CAMINO's Avatar
    Jul 2005
    thankyou MGD, but i use just autoit to accomplish this, no winamp plugin needed.
    Apr 2006
    I just use rr. I have setup a global playlist variable ($playlist$) and use it to add songs, delete songs, rearrange playlist, etc.
    B03,135,340,125,76,"minus1||savelist;$playlistpath $$playlist$.m3u",""
    EL CAMINO's Avatar
    Jul 2005
    good idea, but like i said, this is to erase the file completely, and you're done dealing with it, not just keep it way from Road Runner.
    Apr 2006
    The above will remove it from the playlist for good. As in it won't show up in winamp or the next time you start RR. if you want to delete the file off your harddrive, you should be able to somehow use the 'deletefile' command. I've never used this from a playlist so that might complicate things but it works fine from any browser.
  1. Track name/time dilema
    By Spaghetti in forum Road Runner
    Last Post: 12-19-2005, 11:54 AM
  2. Problem Remembering Current Track Position???
    By marcini in forum General MP3Car Discussion
    Last Post: 06-14-2005, 08:25 AM
  3. Limit inrush current
    By pke in forum Power Supplies
    Last Post: 07-07-2004, 02:41 PM
  4. Replies: 0
    Last Post: 06-14-2004, 10:36 PM
  5. Random LCD idea - track movement?
    By Rover_Eli in forum LCD/Display
    Last Post: 01-22-2004, 11:34 PM
