Results 1 to 10 of 20
Thread: Request - screen transitions
    Jan 2007
    East Central FLA
    I have tried the feature in Roadrunner that provides for various screen transitions, i.e., transition=X in rr.ini (where X runs from 1 through 10 IIRC).
    My idea was to build a skin in which a kind of sign board appeared to slide in/out on some rails to display various menu choices. The problem I have encountered is that the transition happens too fast (1.73GHz Pentium M) to be useful as an eye-candy tool.
    I am wondering if anyone has figured out a way to slow down the transition (that doesn't hurt some other performance aspect).
    If not, then I would respectfully request a variable controlled transition speed be included in the next release.
    I have no idea how difficult what I'm asking for really is, or how many other would like to see this.
    Finally, if I have posted this in the wrong place, please accept my apology.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i had the same idea some month ago...it was too much trouble to have rr do tha natively..
    just learn Flash
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Yea, the only transition that seems to work fine is the fade, all the others just seem like screen flickers.
    Would be really cool though to have your menu screens and specific other screens set to slide in, out etc.
    beer replenishment fund
    mp3car live search
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    what would be really cool is to just have another command on all labels, buttons, etc. to have an entrance/exit command. it might hog a lot of memory, but i think itd be awesome to have some labels fly in from the left or right or to fade in and have some buttons appear or slide up or down or whatever. hey im running a P4 system with at least a gig of memory so i know i wouldnt mind some cool effects. guino has already put alot in tho, so we cant be greedy. im quite content with the fade.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Try this version out,
    Edit: Link and file removed will post a full complete version with only this mod done to it.
    add to rr.ini:
    transtime=0.2 <-- this is currently the default "sleep" time between transition screen updates
    I have also made it so that you can change it by using setvar;transtime;.5
    So what you end up with is a way to really set every transtime for every screen change
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    RoadRunner2.zip
    add to rr.ini:
    Kewl! I am a bit confused however, when I asked Guino some months back about changing the transition times, it was not "do-able". If it really is that easy, it would be very nice to see this added to the official RR release for sure! Also, you seem to imply that it is changeable at runtime, and no restart of RR is needed, is this right?
    My Fiero Build Thread
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Your are correct, your can put "setvar;transtime;.7||MAIN" or whatever screen your going to...hence the option to set the time per usage.
    I'm not really a vb person (mostly just deal with autoit) but this mod only took me a hour to change/figure out. It was as simple as exposing the timer constant that was set and making it changeable at runtime.
    I'm not sure if it would cause any probs though, the only thing that I would add to that is a check for the current value before running the effect, b/c if you put less than .2 it locks up RR.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Blue This screws up "Auto Skin Change" when "Using built in gamma with GPS". It changed to my night skin and would not return to the day skin.
    When I reverted back to the original RoadRunner.exe it reverted correctly to my day skin.
    Any idea what's happening ?
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And...
    You were warned..it was just a 2 sec mod, as I not sure what probs it would cause. That version is also one that it was playing around with some other things so that could just be it too, it would be nice if I had all the required files so that one didn't have to delete the Mapmonkey lines out of every update....maybe gunio was right when he said that it was "not do-able"
    Gunio, if you read this, could you explain maybe as to why you said that this couldn't be done.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Jan 2007
    East Central FLA
    RoadRunner2.zip
    Thanks, I'll give it a try
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  2. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
  3. stuffed screen? im stumped!
    By *blinkey* in forum LCD/Display
    Last Post: 08-06-2006, 10:23 PM
  4. Motorized Flip-Up Screen Ideas?
    By DryBear in forum Fabrication
    Last Post: 01-16-2006, 02:09 PM
  5. Request : Dual Screen Support
    By World705 in forum Road Runner
    Last Post: 11-01-2005, 10:01 PM
