Page 13 of 62 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 617
Thread: RR Config Updated - Blue ZX3
  1. #121
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I meant what I said, in saying that I take great pride in my work, especially something having this MANY ppl using it.
    Would a dedicated RR user stand for anything less...I THINK NOT!!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #122
    Jan 2007
    Im having a prob. Everytime I open RRConfig it sets my XM port to 0. If I dont change it from 0 to 16 before I save the settings it will set it to 0. Is there something else I should be doing?
    Thankyou
  3. #123
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Confirmed...
    Fixed...
    Links Updated...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #124
    May 2005
    The new RR Config.exe sets "sapi5=true" in RR.ini when "Disable SAPI5 and use SAPI4" option is unchecked. This is all fine. However if you revert back to Guino's RRConfig.exe, you will see that "Disable SAPI5 and use SAPI4" option is checked!
    I believe this is a bug in Guino's RRConfig as it doesn't interpret true/false correctly for this parameter. To get around this problem, can you use 1 or 0 instead of true or false. ie "sapi5=1"
    On the other hand, Guino's RRConfig can recognize "phoconodesign=true" or "phoconodesign=1" properly. And when you make changes via Guino's RRConfig, it always write "phoconodesign=true" back to rr.ini if that option is checked. The new RRConfig.exe cannot interpret this correctly and show that the option is not selected instead. It only works with "phoconodesign=1"
  5. #125
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The prob really is that vb handles this true/false or 0/1 the same and when creating the new one I followed the ini readme as far as what the settings are supposed to be...
    And appearently there are some discresions between the ini readme and the actual usage in the old config...
    Will take a look at this also and prob have a fix by days end...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #126
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    a quick question..
    the "remember last browsed location" in the music tab...does it work??
    which field is it in rr.ini?
    Is it "musicbrowse=XXX"?
    cause whenever this field is checked "musicbrowse=" has no value at all, (1or 0)
  7. #127
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Does it work? Y, yes it does...
    There is no "set" value for it b/c if RR see that it exsits in the ini then it will use it to store the last browsed loc, so that when you go back to the audio browser, it starts at that loc..
    It should contain something after you check it and run rr...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #128
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    When Visual Basic converts numeric data type values to Boolean, 0 becomes False and all other values become True.
    When Visual Basic converts Boolean values to numeric types, False becomes 0 and True becomes -1.
  9. #129
    FLAC djmickyg's Avatar
    Feb 2004
    I'm still having truble with the gps speed settings..
    they settings dont seem to save..
    if i unclick the 3 stage mute button.. it's still on next i open it?
  10. #130
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Confirmed...Fixed....
    Links Updated..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 03:35 AM
  2. Video freezes after RR upgrade
    By A-bloke in forum RR Bug Tracker
    Last Post: 09-09-2007, 09:31 AM
  3. Update resume.ini during RR execution?
    By tmar89 in forum Road Runner
    Last Post: 11-01-2006, 09:16 PM
  4. updated config for e815 (MOSTLY everything works!!!!)
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 06-22-2006, 03:00 PM
  5. Replies: 3
    Last Post: 03-20-2006, 09:32 PM
