Page 17 of 62 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 617
Thread: RR Config Updated - Blue ZX3
  1. #161
    Jan 2006
    Lexington, KY
    MAN, you ppl don't speak up very much around here any more
    Maybe because you already fixed everything
    I personally can't find anything else.
  2. #162
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Enforcer View Post
    You want more from me?
    Well, this is a community util, I am up for adding/changing just about anything to better suit the community!
    Just confirming that if it is not present in current skin the preloads will still be listed (but greyed out) if another skin is chosen.
    By greyed out, you don't mean the screens to preload list as a whole? The way it is coded as of currenty, it just doen't get added to the list. But now that you've brought this to mind, I could just simply add a "-" infront of it as to keep it in the list but would be ingnored by RR when running through all the preload screens, and if you change the skin to one that does include that screen, it will just remove the "-".
    Does that sound better, I think so. Other wise if I leave it the way it is, everytime you change skins, you would have to re-add those same screens back again
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #163
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    No, you got it, that should be fine.
  4. #164
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Updated version:
    Fixed:
    *weatherunits
    Added preload functions:
    *if skin file is not in current skin path and/or contains the "/discardable" setting it gets turned off
    *above gets updated; when running the config or changing the day(standard) skin path
    *if the preload gets turned off,:
    __a. the skin the preload list gets a "-" infront of the file( ie.."-audio_player.skin")
    __b. gets entered in rr.ini with a "-" infront of the preload setting ( ie.."-Preload=audio_player.skin")
    It will also organize them when added to the rr.ini file with the off's being listed last in that section
    Links Updated..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #165
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    missing setting alert
    picspath=XXXXXX
  6. #166
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Nomader View Post
    picspath=XXXXXX
    Shouldn't be showing pr0n in your slide shows.
  7. #167
    Apr 2006
    Greece
    picspath feature removed due to forums ethics
    and a small bug..in the web browser selection...it opens a "folder select" window when the setting for that should be the browsers executable
    eg
    browserpath=C:\Program Files\Internet Explorer\IEXPLORE.EXE
    and not
  8. #168
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Noted...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #169
    Apr 2006
    Greece
    good!!
  10. #170
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Update..
    Fixed:
    *file/folder select for web browser
    Added:
    *picspath
    Links Updated...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 03:35 AM
  2. Video freezes after RR upgrade
    By A-bloke in forum RR Bug Tracker
    Last Post: 09-09-2007, 09:31 AM
  3. Update resume.ini during RR execution?
    By tmar89 in forum Road Runner
    Last Post: 11-01-2006, 09:16 PM
  4. updated config for e815 (MOSTLY everything works!!!!)
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 06-22-2006, 03:00 PM
  5. Replies: 3
    Last Post: 03-20-2006, 09:32 PM
