Page 2 of 62 FirstFirst 12345678910111252 ... LastLast
Results 11 to 20 of 617
Thread: RR Config Updated - Blue ZX3
  1. #11
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    Where do you comment or erase this line?? mine is giving me an error:
    Line 0 File C:\Program Files\RoadRunnerBianry\RR Config.exe
    For $i=1 To $sndcrd[0][0]
    For $i=1 To $sndcrd^ERROR
    Error: Subscript used with non-Array variable.
    I know the basic of prog so, tell me what to change I'll do it and post the Issue/resolution after. Thanks!
    Quote Originally Posted by fixerofallthing View Post
    Mine hangs as well but if I comment out or remove the reference to SAPI it works fine. I do not know if it is just me but that is all I chnged to get it to work.
    THANKS for the hard work!!
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
  2. #12
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by VmtSquad View Post
    Different issue, PM sent..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #13
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Current config size ok? Yes / No
    I haven't really used it on anything smaller than 1280 * 1024, dont like small screens execpt for car usage. I tried to keep it in a 800*600 size limit.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    If I was to embed it into the iDive skin I would need it to be 800x516 at it's largest really so at 671 x 459 it will fit OK but need some padding. Other skinners may have their own requirements.
  5. #15
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Found error and some others that slipped by...
    Redownload new version.
    RR still halts on startup
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  6. #16
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Remove the 'sapi5=' line in rr.ini under [General] only first time.
    I'm still finding typo's and mistakes, you type 3176 lines of code and see if you make NO mistakes.... We're getting there.
    More mistakes fixed and also added the Fade-in Volume option (gen pg3 on by default)
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #17
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    niiiiiiiiiiiiice..hope it will stay updated.. it is one step of making RR more noob friendly
    EDIT: actually veeeeeeeery nice..
    NOTE: some settings are not read correctly from rr.ini, the first time..so the first time one has to reconfigure?
  8. #18
    May 2006
    Simi Valley, CA
    Haven't tested this out in the car yet, but looks good.
    I found a typo in the Map Master Volume to Control Line: (For Wead Sound Cards).
    What's really on your mind?
  9. #19
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thats really funny, all these DL's so far and your the only one who noticed it.
    <-- has to go and check for himself
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #20
    Apr 2006
    Greece
    ok i was wrong..don't hurt my feelings
    EDIT..Iwas not wrong.. the "use line in plugin" in RADIO, is checked in the old config, abd not checkd here..the thing is that the text that is supposed to have the line in parameters...is.....wher is it??
    and it is supposed to be grayed out when the checkbox is not checked..but it is not greyed..if i check an then uncheck..it greys out..
    NA NA..NA NA NA
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. Video freezes after RR upgrade
    By A-bloke in forum RR Bug Tracker
    Last Post: 09-09-2007, 10:31 AM
  3. Update resume.ini during RR execution?
    By tmar89 in forum Road Runner
    Last Post: 11-01-2006, 10:16 PM
  4. updated config for e815 (MOSTLY everything works!!!!)
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 06-22-2006, 04:00 PM
  5. Replies: 3
    Last Post: 03-20-2006, 10:32 PM
