Page 20 of 62 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 617
Thread: RR Config Updated - Blue ZX3
  1. #191
    Newbie RedArrow's Avatar
    Nov 2006
    Hi, Road Runner users.
    I'm from Spain, and I know there are Road Runner user all around the world. And not all users speak English, so, could the RR Config include a file with the translation for each language?
    I offer volunteer to translate it to spanish.
  2. #192
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    It did breifly cross my mind, and I know that would make it just that much better...although that would req a lot of code changes...
    I can add it to list and when i'm ready for that stage, I'll PM you and send you the text to be translated...
    Still trying to get this new version out, didn't exactly make that "<24hrs" thing...LOL
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #193
    Variable Bitrate walstib's Avatar
    Jul 2005
    Atlanta, GA
    RedArrow,
    Your icon is outstanding!
    Carputer Project Status:
    0% - Mobo died on 2/17/08
    Check out the worklog for my '01 Pathfinder.
  4. #194
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'll second that!!!
    Ok, Now
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #195
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    for some reason why when I use this my radio setting and stuff get change everytime i go into this RR Config. Also my setting keep on getting set back to the default state. meaning in the tag info i do not want the -, but it always put that back.
  6. #196
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Update!
    Fixed:
    * Titlesafter
    * AVS Section shows saved saved settings now
    Added:
    * Disable other iGnative options if igautosw is not set
    * Upon checking/using iGnative option, checks whether the 'external_gps.skin' and/or 'external_gps_full.skin' file(s) contain a non commented out clip region and if found ask user if they would like it to be fixed.
    * Upon checking/using the iGnative 'pause on voice...' option, checks the exectlb file for any igpause/igresume commands and if non found then asks user if they want it to be added to the file (lower volume instead of pausing music).
    * If user had it add those settings, also confirms that they were added, where to find commands added, and lastly tells you how and what to change if you don't like the default setting.
    * Option to backup INI file with the following options (config tab at bottom):
    __backup off/on
    __backup path
    __File format
    __Number of backup file(s) for that date
    * option to turn off "IGPAUSE" msgwin if don't want to use other suggested option (on config tab)
    Links Upated...
    PS. when posting prob, PLEASE, PLEASE, be very detailed in what prob you are having, better description, faster fixes...Thanks!
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #197
    Jan 2006
    Lexington, KY
    Excellent! Can't wait to get home and test this out. Especially the INI backup utility (thanks for listening BTW ).
  8. #198
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I also forgot to mention that there are two additional setting that only apply to sonic's last beta release. They are the auto weather update and backround path.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #199
    FLAC djmickyg's Avatar
    Feb 2004
    the download isnt working?
    is the alternative upto date? it didn't look like it
  10. #200
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Power went out this morinig around 4:45 and went through a couple of on/off cycles so I just left it off till this morning before heading to work...
    Should be ok now.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Is there an Alpine blue for RR?
    By turbosx in forum RR Skins
    Last Post: 06-01-2008, 04:35 AM
  2. Video freezes after RR upgrade
    By A-bloke in forum RR Bug Tracker
    Last Post: 09-09-2007, 10:31 AM
  3. Update resume.ini during RR execution?
    By tmar89 in forum Road Runner
    Last Post: 11-01-2006, 10:16 PM
  4. updated config for e815 (MOSTLY everything works!!!!)
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 06-22-2006, 04:00 PM
  5. Replies: 3
    Last Post: 03-20-2006, 10:32 PM
