Switching between RR and copilot
I'm working on a new setup that uses RR for media player and ALK Copilot for GPS. I've configrued both to leave enough space for a task switcher called ObjectDock. ObjectDock has a nice feature where a shortcut will launch one instance of a program and switch back to it on subsequent clicks. This works like a charm with Copilot, every click will bring the guidance window to the foreground. But RR doesn't seem to want to budge! Click the shortcut 1st time works and launches RR. But once other apps are in front, RR won't come to the foreground. It is not minimized, just in the background. If I click the RR taskbar icon, RR will switch to the foreground just fine.
I see my options so far:
1) maybe it's a small issue in RR that I (end user) can fix.
2) find another utility that will call the RR window properly.
3) drop the shortcuts and use the task bar icons to switch.
Anyone know why RR doesn't come to the foreground?
