Results 11 to 20 of 22
Thread: Picture Path in RR
  1. #11
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Enforcer View Post
    Look for a space that should not be there on the button command.
    Damn forum
    Jees Still 1 out of 2 can't be bad.
    You'v e go t t o b e goo d t o b e i n thi s Clu b, haven' t yo u !
    Thanks, works great now
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  2. #12
  3. #13
    Constant Bitrate funkyphil's Avatar
    Sep 2007
    CHI-TOWN
    Cool Would like some help with my configing my pic viewer
    I know Nothing about skinning and it sounds to me that I have to do some kind of coding to get my pics to work in my rr / digitalFX 3.0 SKIN. Is this true? If so Please dumb it down for me, I have spent about three hours or so tonight just going through the FAQs and searches.
    I can not make heads or tales of how to setup my pics to view.
    Thanks Phil
  4. #14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I suspect DigitalFX3.0 already has a picviewer in it, therefore I would first of all read the helpfile provided with the skin and failing that read the release thread for the skin.
    Then if you get no answers ask in the thread for the skin.
    First point to look at is whether you have set up the picspath in RRConfig to be where your pics are.
  5. #15
    Sep 2007
    CHI-TOWN
    Enforcer,
    Could you tell me how to setup a picpath in rr, I thought it would be as easy as setting up music but it isn't. There is an INI Path: (not current dir) in player 1 setup as well as Launch Path: and I have No idea what is suppose to go here. Could this be why i am having problems? Sorry to sound dumb just trying to learn as much as I can in a short time.
    Thanks Phil
  6. #16
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by funkyphil View Post
    Enforcer,
    Thanks Phil
    define your picspath in rrconfig.
    copy and paste "picviewer.skin" into your skin if it doesn't exist.
    create a button in your skin using RRSkinEditor w/ the code "PICS"
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  7. #17
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Enforcer,
    Thanks Phil
    here you go
  8. #18
    Sep 2007
    CHI-TOWN
    Thanks Enforcer,
    However I think I have it wrong? I have attached a how I have it setup.
  9. #19
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    if that's where your pictures are then that should be fine. (unless RR has trouble with spaces in the path)
    Hmm, just had a quick look at the DFX skin files and it may not use the default RR picviewer, it may use a seperate plugin, you will need to read the DFX thread and ask questions in there if there is no answer already there
  10. #20
    Sep 2007
    CHI-TOWN
    Smile Thank you Enforcer
    Enforcer,
    Thank you sir for your time and help. I will do just that, I also wanted to say I downloaded your traffic cams last night and I am not having any luck getting them to work. Could you dumb that down for me maybe in a pm sometime?
    Thanks again sir
    Phil
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. XMD RR Hibernation & XMRESET
    By hank_kls65 in forum Road Runner
    Last Post: 10-25-2007, 04:14 PM
  3. Girder stops working when RR is launched
    By BlackStealth in forum Road Runner
    Last Post: 09-07-2006, 08:35 PM
  4. feat req: RR path as system variable
    By liquid_smoke in forum Road Runner
    Last Post: 07-19-2006, 08:07 PM
  5. General question about the RR program logic
    By DaveB in forum Road Runner
    Last Post: 03-20-2006, 12:26 AM
