Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Picture Path in RR
    Nov 2006
    Picture Path in RR
    I have been running RR for a while and have figured out a lot on my own. The only thing I cant figure out is how to set the path for my pictures. I would like to be able to view my pics in RR. Can someone help??
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    I don't think RR does pictures natively. You need to download and install ImageViewer to your RR directory. Then edit the ImageViewer_Config.ini, line Init_Path =(path)
    Imageviewer might get installed with RR i'm not sure, so check your RR directory first. But ImageViewer_config.ini is where you set the path.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RR does do pictures natively.
    picspath=
    is the line in rr.ini you're looking for.
    you will need a picviewer.skin
    which should have a 'J' line
    J01,220,042,580,514
    NEXTPIC and PREVPIC and the buttons to move bewtween the pics
    to do a slide show have a button
    Code:
    "BYVAR;SLIDESHOW;SETVAR;SLIDESHOW;1<<SETVAR;SLIDESHOW;0",""
    to turn on and off
    a
    TMR,x where x is the amount of seconds between switching
    and in your ExecTbl.ini
    Code:
    "TIMER","BYVAR;SLIDESHOW;<<NEXTPIC",PICVIEWER.SKIN
    Nov 2006
    Are you reffering to Fast Stone's ImageViewer? If not, please provide a link to the one you are referring too.
    Thanks,
    Nov 2006
    Ahh sweet, thanks Enforcer. That is what i was looking for. I am a bit of a nub, so i didnt dig any further then the RR config.exe.
    Also, thanks for the Idrive Night. People freak when they see it!!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    iDrive Night should have the pic viewer, just look at the picviewer.skin and exectbl.ini in that.
    edit BTW there is a new RRConfig on the block, that should have the picpath setting.
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Enforcer View Post
    picspath=
    J01,220,042,580,514
    "BYVAR;SLIDESHOW;SETVAR;SLIDESHOW;1<<SETVAR;SLIDES HOW;0",""
    to turn on and off
    a
    "TIMER","BYVAR;SLIDESHOW;<<NEXTPIC",PICVIEWER. SKIN
    Hi E. Looking to add the Slideshow feature to my Picviewer.
    I've copied and pasted your info to my installation and made the button, but it doesn't work. Any idea what I've missed
    Could it have anything to do with the exclamation marks
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Nov 2004
    Leicestershire UK
    Show me your exectbl.ini and picviewer.skin
    BTW what exclamation marks?
    Sorry I meant "Quotes"
    I have found out what the problem was...there was a space between the PICVIEWER.(>SPACE>)skin entry in the ExecTbl.ini. It now works.
    I think that was something to do with the idiosyncracies of the Forum software..I've seen it enter spaces itself before.
    BUT I still have a slight problem.....I can start the Slideshow...but how do I stop it. Hitting the button again doesn't work !
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by wizz View Post
    Look for a space that should not be there on the button command.
    Damn forum
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. XMD RR Hibernation & XMRESET
    By hank_kls65 in forum Road Runner
    Last Post: 10-25-2007, 04:14 PM
  3. Girder stops working when RR is launched
    By BlackStealth in forum Road Runner
    Last Post: 09-07-2006, 08:35 PM
  4. feat req: RR path as system variable
    By liquid_smoke in forum Road Runner
    Last Post: 07-19-2006, 08:07 PM
  5. General question about the RR program logic
    By DaveB in forum Road Runner
    Last Post: 03-20-2006, 12:26 AM
