Don't know if this will sort it out for you but in RR config make sure that your volume is mapped to "Master Volume" and Not "All Lines"
Hi at all.
I'm Italian, sorry for my english.
I hava a problem with road runner. If i open rr and i close it the Wave volume in Control volume(open icons of sound in down-right of apllications bar) is set to 0.
So i can't listen the sound of Windows, after i open rr!
I post an image of problem when i close rr.
thanks for support
Hi, You must uncheck "mute winamp on rr exit" in rrconfig.exe
See attach image.Bye
Volume is mapped on Master Volume.
Is it possible to uncheck "mute winamp on rr exit" in normal rrconfig,exe?because I don't have that version of rrconfig.
thanks so much
Add this to your rr.ini then.
exitmute=false
It should work.
Thanks you very much Robterza.thanks thanks thanks thanks...
