+ Reply to Thread
Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: Launch OBD program inside RR
    Variable Bitrate seninha's Avatar
    Dec 2005
    Holland
    I just tried everything that is explained in the FAQ . But somehow I just can start the OBD program that I normally use inside RR.
    When I use Winspector to see what the windowsearchstring must be, everything is blanck overthere . So I just dont know what to fill after that.,
    The OBD program I use is THIS
    Hope that someone can help me make this work.
    I already tried the next INI file
    [GENERAL]
    PATH=C:\Program Files\OBD-DIAG\OBD-DIAG.exe
    TryEmbeddedTimeOut = 5
    WindowSearchString=OBD-DIAG
    But it just wont start
    Gods right foot!!
    Renault Grand Espace 3.5 V6
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    try this code;
    Code:
    "load;obd.skin;obd;C:\Program Files\OBD-DIAG\OBD-DIAG.exe;OBD-DIAG"
    Dec 2005
    Holland
    Sorry, but is this not a code if you use a special Button to launch the application??
    I just want to start the program by using the Launch skin .
    Last week I added fanspeed to the launch list, and this work whitout any problem.
    When I press the launch butto (inside the Launch skin) fanspeed starts up and works fine.
    Only this OBD program doesnt want to
    Gods right foot!!
    Newbie Robterza's Avatar
    Dec 2005
    Rome
    Quote Originally Posted by seninha View Post
    You cannot embed that program, i dont know why,it will only work on top of road runner. i have already tried it.It will "close" or "exit" with his own button on screen.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well it seems to embedd fine in my launch wiondoe. Although it doesn't resize, so you are better off doing a .skin file for it.
    And seing as it's skinnable it might be worth doing a akin for it to match the skin you are using.
    Dec 2005
    Rome
    This is good news for us, can you share the code for that? Thanks
    Dec 2005
    Holland
    I think I'll give it try and just embedd it in RR and change the buttons of the original program to match my skin (Mauri )
    Only have one question. When I put the code (mentioned above by ElCamino)under one of my buttons in the Menu.skin, and press this one doest the OBD program open above RR??
    This was the code before:
    B01,17,187,215,110,"GPS","" BEFORE
    And now changed to open the OBD program:
    B01,17,187,215,110,"GPS","load;obd.skin;obd;C:\Pro gram Files\OBD-DIAG\OBD-DIAG.exe;OBD-DIAG" NEW CODE
    Will this work ??
    Gods right foot!!
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Robterza View Post
    same as OP
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    try
    Code:
    B01,17,187,215,110,"load;obd.skin;obd;C:\Program Files\OBD-DIAG\OBD-DIAG.exe;OBD-DIAG",""
    EL CAMINO's Avatar
    Jul 2005
    funny looks so familiar, the code!!!
+ Reply to Thread
  1. RR application launch
    By qseven in forum Software & Software Development
    Last Post: 03-29-2006, 09:29 AM
  2. Sending RR commands to RR inside FD.......
    By Spaghetti in forum FreeDrive
    Last Post: 12-24-2005, 07:49 AM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  4. How to tune TV station inside RR
    By cyberlancer in forum Road Runner
    Last Post: 05-09-2005, 01:14 PM
  5. Running a program inside a program
    By CaffeineAddict in forum Software & Software Development
    Last Post: 10-16-2002, 04:26 AM
