Results 1 to 10 of 12
Thread: Roadrunner as shell reloads when shutting down
    Aug 2004
    Germany
    I have a problem. I changed the shell as described in this thread (page 1):
    http://www.mp3car.com/vbulletin/faq-...front-end.html
    I guess it works as it should:I changed the registry key to start RoadRunner. Now when I reboot RoadRunner runs as shell. When I exit RoadRunner it automatically restarts. So far so fine.
    But when I want to shutdown the computer, RoadRunner quits and then windows tries to restart it. But it can't because the shutdown-procedure is initiated. So a Windows message window appears saying "The application failed to initialize because the windows station is shutting down". Why does the system do that ? When I shutdown it obviously shouldn't restart the shell. I also set "AutoRestartShell" to 0, which doesn't make a difference.
    So, how do I prevent RoadRunner from restarting ?
    Feb 2007
    Croydon UK
    you might
    be better off asking this question on the thread you have posted.
    Aug 2004
    Germany
    I get the impression that this is a Roadrunner problem, because this doesn't happen when explorer.exe is configured as shell. That's why I thought that I'd better post this question here.
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    Quote Originally Posted by Konrad View Post
    this is not a RR problem. this will continue to occur with whatever shell you choose. thats why sometimes when windows freezes, and explorer shuts down, it restarts. windows is set to restart the shell whenever it is shut off.
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    are you using minlogon?
    Aug 2004
    Germany
    Quote Originally Posted by tundra2000
    That's what the registry key "AutoRestartShell" is for. And I already set it to 0.
    @ElCamino:
    Yes, I'm using MiniLogon.
    EL CAMINO's Avatar
    Jul 2005
    thats why, when you add the registry from minlogon hack, that setting is add it as well, but i can see you fix your problem already.
    Aug 2004
    Germany
    Not really. I want to use minilogon instead of winlogon to increase performance . Any idea how to solve this problem ?
    EL CAMINO's Avatar
    Jul 2005
    "AutoRestartShell"=dword:00000000 this shut be the fix.also as far as i remember the only value that you need to add to the winlogon registry is this one.
    "Config"=dword:00000017
    why dont you try another front end, even explorer and see if that makes any difference
    Aug 2004
    Germany
    I've already set/added both values. I get the impression that this is a problem with TinyXP. With my last standart WindowsXP installation I didn't have this problem .
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 04-12-2012, 07:29 PM
  2. Replies: 2
    Last Post: 11-05-2006, 08:41 PM
  3. Problem shutting down with RR as shell
    By flipster125 in forum Road Runner
    Last Post: 04-17-2006, 02:02 AM
  4. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
  5. Roadrunner as shell - Needs run
    By Cobelli in forum Road Runner
    Last Post: 05-31-2005, 03:18 PM
