Results 1 to 8 of 8
Thread: Using Phone Control SKin
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi I am using the original Phone control and every thing works fine.....
    Now can some 1 pls help me to integrate this PhoCo in RR so that i can use the PHONE button on DIGITAL Fx skin...
    I wish to use the original skin of Phco and its features....
    all i need is where and what path do i type in so that when i click Phone button it connets to Phco to show the skin that i want ... ( NOt the Ditial Fx skin of Phco )
    thanks in advance
    vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Dec 2003
    Well read that and got the name and class fine...
    but the question is what and Where do i put in the path so that this PhCo launches on pess of the PHONE button in the DIGITALFX screen
    I DO NOT want it in the UTILITES and EXTernal application..
    I would love it to be launche dfrom the PHONE button
    thankx
    vicky
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Well, first you will need a .skin file where you embed the application. Then you have to define the A definition for the embedded application
    A,0,50,750,400, or whatever, then in the MENU.skin change the button to...
    B xxx,xxx,xxx,xxx,"LOAD;?.skin;Phone Control;C:\Program Files\PhoneControl.net\PhoneCTL.net.exe;WindowName ".
    Then it should look like this.
    Dec 2003
    WOW man this is what i want and u hit the bulls eye
    thanks will try out and see
    may be i post in a few more times to bother u for ur help if i get stuck...
    thanks once again
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    Dec 2003
    Ok just wanted to know is it NOT possible to link the PHONE button directly to the Phonectl.net.exe
    so that it is launched from the original file insted of making new skin and sub skins.... with all the functions
    thanks
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    Jan 2007
    Im trying to this as well. I just took the menu.skin file that was already in the digital fx 2.0 folder and changed the freefone line to make it point to the phonectrl.net.exe
    B xxx,xxx,xxx,xxx,"LOAD;?.skin;PhoneControl;C:\Progr am Files\PhoneControl.net\PhoneCTL.net.exe;PhoneContr ol"
    I left the numbers after the B. Am I doing something wrong? Because PhoneControl is not opening at all.
    Thankyou.
    Jan 2007
    ok, i think i got it working using the solitaire.skin Now i just have to make it fit in the screen.
