Results 1 to 9 of 9
Thread: How Do I Disable RR key press sounds?
    Constant Bitrate rsxtypes's Avatar
    Nov 2006
    Dallas, Tx
    How do kill the sounds RR plays when I press a button? They play pretty loud when I have something paused and are pretty rough sounding on my system. I am using FU if it matters.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    disable voice in RRConfig.exe
    beer replenishment fund
    mp3car live search
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by rsxtypes View Post
    If you are using a touchscreen there is also an option in most TS software to provide an audible tone for key presses. You might like to check and make sure this is disabled.
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Nov 2006
    Dallas, Tx
    I removed the touchscreen tones first thing when I started using the touch screen. I tried disable the voice in the RRconfig. That works for the BMV skin. It apparently is different for the Freedom Ultimate skin because they still are playing
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    u gotta disable sound in FU setting if it has it most likely it does
    Nov 2006
    Dallas, Tx
    I haven't found one in the FU options either. I think it is still an alpha version so he may not of added it yet. I have even been looking for the .wav file to try to delete them or record some dead air clips and replace them.
    Nov 2005
    I know that the sounds in Freedom 2.1 are embedded within the flash (or something like that) so you cant take them out. There is a NO BUTTON SOUNDS option, but some button sounds still play.. I think that feature remains a little buggy/unfinished. I imagine that FU is similar. I'm sure CDR will get around to it when he has some time
    Nov 2006
    Dallas, Tx
    Thats what I was starting to think. Thank you for confirming it for me.
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    in the oposite way, i wanna activate the key press sound, but not the voice, just a click when pressing any button (no touchscreen to do it here ). is there a way to do it?
    []s
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 06:41 AM
  2. Super small XP install
    By knubile in forum WinNT Based
    Last Post: 04-26-2008, 03:44 PM
  3. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  4. nLite and USB Devices
    By Nobias in forum WinNT Based
    Last Post: 01-20-2005, 11:11 PM
  5. nLite making me nSane: Frodoplayer issue
    Last Post: 01-13-2005, 01:09 AM
