Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: RR wont start
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    RR wont start
    When I try to run RR it shows the splash screen with starting winamp, my start button and taskbar disapear, then I hear the windows critical stop bong, then winamp starts, then its all hung, I can alt-f4 to bring winamp to the front and exit it, but the RR splash screen just says not responding.
    I have to 3 key, kill RR, then kill explorer and restart it to get my taskbar back.
    Odd as I dont have 'hide taskbar' in the config.........
    Its also taking about 50% cpu use in its hung state.
    I have tried using RR config, re-downloading winamp, and re-downloading the RR binarys (did not fix it.)
    also when I did downloaded the installer, it links to rrdownloads.net, which seems to have become a portal for advertising spam
    (and didnt fix it either)
    I have virus checkers installed and anti spamware, I dont think I'm infected, I dont p2p for executable files, and everything else is still fine.
    So, anyone else problems starting RR at the moment?
    Lez, more widely known as flez1966
    Mar 2006
    Colorado, but Canadian!
    nope no problems, but it sounds like your installer is prettty outdated if it asks for the old site. Someone here made a new one, try it first.
    And if it hides the taskbar and you told it not to, then obviously the config file is messed up. Check in there.
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    yeah thought it would be just me lol.
    it was working last time I ran it, about a month ago.........
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    ok had a look in debug.tx says its images........
    So I just reinstalled, and downloaded a skin I have never used before etc, and I get this.......
    road runner splashscreen (from skin)
    bong critical stop
    winamp
    50% cpu usage
    application hung.
    debug.txt says
    20/07/2007 22:40:47: Start -- Version: 12/04/2007
    20/07/2007 22:40:47: Master Vol: Volume Control/4
    20/07/2007 22:40:47: GetLineControl Failed: 401
    20/07/2007 22:40:47: No Treble Support
    20/07/2007 22:40:47: No Bass Support
    20/07/2007 22:40:47: No Master ON/OFF
    20/07/2007 22:40:47: Source: Wave=&H1008/1
    20/07/2007 22:40:47: Source: SW Synth=&H1004/2
    20/07/2007 22:40:47: Source: Front=&H100A/3
    20/07/2007 22:40:47: No Mute for Source
    20/07/2007 22:40:47: Source: Subwoofer=&H100A/4
    20/07/2007 22:40:47: Source: Center=&H100A/5
    20/07/2007 22:40:47: Source: Rear=&H100A/6
    20/07/2007 22:40:47: Source: SPDIF=&H1001/7
    20/07/2007 22:40:47: Can't Open Source
    20/07/2007 22:40:47: Source: Aux=&H100A/8
    20/07/2007 22:40:47: Source: CD Player=&H1005/9
    20/07/2007 22:40:47: Source: Line In=&H1002/10
    20/07/2007 22:40:47: Source: Microphone=&H1003/11
    20/07/2007 22:40:47: Source: Phone Line=&H1006/12
    20/07/2007 22:40:47: Source: PC Speaker=&H100A/13
    20/07/2007 22:40:47: ERROR loading image file(s) for: menu.skin
    20/07/2007 22:40:47: SDK command: REQUEST;MotionLock;RRPATH
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by 2k1Toaster View Post
    Ok deleted the whole lot, downloaded the installer as linked on post 1 in the RR thread, on the install screen it has a link for winamp to:
    http://rrdownloads.net/winamp295.exe
    which seems duff.
    RR_updater.exe fails and whines about variables (subscript used with non array variable)
    And its still not working..........
    Mar 2006
    1.9in x 2.9in -- 47mm x 73mm
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    yup, that one, the installer, when it stops to tell you to download the right winamp, if you click on the link...............
    Oh and if I drop the updater from updater.zip into my RR directory, it says (Your Version is: 2007/04/12) , then update available, and then download failed...
    {edit}
    Ok now have /latest/ RR version, and updater say I'm upto date
    BUT........... It still wont damn start and just ''stops responding''
    No useful errors in debug.txt, its about as much use a windows 98 core dump, which is just annoying at a programming level.........
    A debug output should do just that, tell you whats gone wrong!
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Come on someone else must have had this problem !
    Grief if I dont find a way to start it soon I may go back to FP !
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I usually just skip the installer and DL the binary. It gives you much more control on how things are set up. RR installers are a 'one size fits all' attempt to set your directory paths for installation. Best bet, download the binary, read all the txt files and run rrconfig.exe from the binary folder when your ready to setup RR.
    Make sure you have a valid skin installed and RR knows where to look for it (set in rrconfig.exe)
    Raw Wave
    Jun 2004
    On the beach
    Try starting with the standard BMV2 Skin.
    Those are the two lines stopping RR from running.
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. XMD RR Hibernation & XMRESET
    By hank_kls65 in forum Road Runner
    Last Post: 10-25-2007, 04:14 PM
  3. Before I start a skin, can RR do this?
    By wilsonj in forum Road Runner
    Last Post: 01-04-2006, 08:23 PM
  4. Generalized Perception of RR from a new user
    By replicant in forum Road Runner
    Last Post: 11-15-2005, 11:41 PM
  5. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
