Don't know, do you have the folder "PhonePics" in you SKIN Folder and named the pic exactly as the number? That's where mine is and it works just fine. See.....
OK I am having a problem with picture showing up in freephone. I set everything as what CDR readme files said to do. Name the picture the same as the number calling and put it in phonepics. Did that but still no picture just a pic of what is set as default. Any help appreciate.
Yeah i have phonepics in my skin. I even name it correctly. for example if a number calling me at let just say 4596590125 is calling. I name the picture 4596590125.jpg. nothing comes up. Does it matter if i am using a WM5 device because the name doesn't even come up all it say is unknown.
I just made a test and deleted the WORK number form my phone. Now when I call from WORK no picture shows up. So, I think the picture only will show when you have the number in your phonebook on the phone and reload the phonebook in freefone.
Finished testing. Stand correct. Added the WORK number back into my phone, started freefone, reloded my Phonebook, called myself from WORK and the picture showed up again.![]()
I dont think this will work with my phone then. Because when people call it just show the number and not the name that is in my phone book.
The only other way is to use the PhoneBook.txt from freefone and change it in the settings.ini "usephonebook=true". Then put all your numbers in there with the format John - 09478383939. Then it should show the name and the number
try using the freefone version thats in with the iphone skin as I added some extra code to grab the callers number, that might help
CDR i am using that and its not helping. I just think its my MDA. When a number dials in or when i dial out with the person in my phone list. It doesn't show the name just the number so i guess i am kinda out of luck with the picture deal.
last question does the number have to have a 0 in the front just a question or just a phone number
