Results 1 to 10 of 10
Thread: Help with SENDKEY command
    Oct 2005
    Raleigh, NC
    Hi,
    I'm planning to use a set of key strokes to perform different functions in RR, depending on which screen is in the forefront. For testing purposes, I mapped the "U" key as Test1 and the "D" key as Test2 in the KeyTBL.ini, then made the necessary entries in the ExecTBL.ini. The audio player responds correctly when I press the U and D keyboard keys, but nothing happens in Guidance 3.1. As a proof of concept, I also tried SENDKEY;{g}" and SENDKEY;{a}" (known hotkeys in IG) and still no response. I am not using a modified iGuidance, and have IGNATIVE=TRUE in RR.ini.
    Would one of the gurus kindly take a look at the syntax and offer some suggestions?
    Thank you,
    RRG
    KeyTBL.ini
    85,"TEST1"
    68,"TEST2"
    ExecTBL.ini
    "TEST1","PGUP",audio_player.skin
    "TEST1","ACTIVATE;iGuidance||SENDKEY;{up}"||GETFOC US",external_gps.skin
    "TEST2","PGDOWN",audio_player.skin
    "TEST2","ACTIVATE;iGuidance||SENDKEY;{down}"||GETF OCUS",external_gps.skin
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I havenothing in my KEYtbl.ini or in Exectbl.ini.
    In my GPS screen I have those commands for zoom in and zoom out and they work just fine.
    B17,684,449,112,69,"SENDKEY;{DOWN}","Zoom Out"
    B18,684,371,112,78,"SENDKEY;{UP}","Zoom In"
    Oct 2005
    Raleigh, NC
    Hey MGD,
    My skin parameters are the same as yours, and it works fine with the touch screen.
    I'm trying to add a level of customization, via keyboard input, so the 2 ini files need to have those entries. I combed through the posts, and believe all is set up correctly. I suspect iGuidance is not getting into focus. The window display name is "iGuidance"
    I also removed the entries for the audio_player.skin, in case of some conflict, but still the same result.
    Please send me your suggestions.
    Thanks,
    RRG
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Look at your code very closely..
    "TEST1","ACTIVATE;iGuidance||SENDKEY;{up}"||GE TFOC US",external_gps.skin
    "TEST2","ACTIVATE;iGuidance||SENDKEY;{down}"|| GETF OCUS",external_gps.skin
    After the {up} and {down} remove the "
    Maybe try to remove the ACTIVATE;iGuidance since you run it natively.
    Oct 2005
    Raleigh, NC
    MGD,
    I tried your suggestion, and the following, but still no go.
    "SENDKEY;{DOWN}||GETFOCUS",external_gps.skin
    "SENDKEY;{DOWN}||GETFOCUS,external_gps.skin"
    "SENDKEY;{DOWN}",external_gps.skin
    "SENDKEY;{DOWN},external_gps.skin"
    As an additional test, I created this entry: "TEST2","SENDKEY;{DOWN}".
    The audio player and iGuidance did not respond this command.
    I then created "TEST2","DOWN" and audio worked fine, but iGuidance didn't.
    Thoughts?
    Oct 2005
    Raleigh, NC
    Thanks Enforcer. Isn't sendkey command the same as pressing a keyboard key? When I am in iGuidance, and press the arrow up, arrow down keys on the KB, IG responds correctly.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Yes and no, it depends on whether the software is set up to accept use of sendkeys, I believe iG3 isn't whereas iG2 was.
    I know for example Red Deaths Mobile Emulator isn't. (you can control it using the keyboard but it doesn't recognise sendkeys).
    Have a search for other threads regarding iG3 as this was one of the reasons skinners had to change the way their skins interacted with iG and use autoit plugins etc.
    Oct 2005
    Raleigh, NC
    Thanks for clearing this up! I'll work on a different approach.
    RRG
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    KeyTBL
    38,"PCiGZoom+",EXTERNAL_GPS.skin
    40,"PCiGZoom+",EXTERNAL_GPS.skin
    ExecTBL
    "PCiGZoom+","SENDKEY;"{up}||ACTIVATE;Road Runner"
    "PCiGZoom-","SENDKEY;"{down}||ACTIVATE;Road Runner"
    This is what I use.
    This was button code from JohnWPB's original Blue Devil skin.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  1. request: exclude command on .skin
    By liquid_smoke in forum Road Runner
    Last Post: 11-03-2006, 07:41 PM
  2. Sendkey not working
    By ThunderStick in forum Road Runner
    Last Post: 09-12-2006, 07:28 AM
  3. SpeakEasy Voice Recognition - Beta 1
    By ruairi in forum Road Runner
    Last Post: 08-23-2006, 12:12 AM
  4. Set a pause with Sendkey command?
    By Mattkins99 in forum Road Runner
    Last Post: 10-11-2005, 03:35 AM
  5. Anyone understand Java ? I need help.
    By frodobaggins in forum Software & Software Development
    Last Post: 05-24-2004, 11:53 PM
