think the commands are in the road runner help file in the roadrunner folder, that will explain all of it, otherwise should be in the faq section on the forum http://www.mp3car.com/vbulletin/rr-faq/
Sorry but I can't seem to find the shortcut or command in RR for toggling Pause/Play music playback? Trying to get my Logitech Nulooq navigator to work with RR now.
Thanks for your help.
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
BTW the help file is in the main RR folder, and is named "SkinCOmmands.txt" It is the "Bible" for all Road Runner commands, and the syntax for use.
My Fiero Build Thread
Maybe we should rename it then to "Skin Command Bible.txt"....LOL No, couldn't do that....4-C (not C4, Ca-BOOM) probs with that already...
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Found it, thank you guys.
I wonder if it would be easier to set up music control via RR or winamp instead? My problem is when it comes to the GPS screen where iGuidance and RR are 2 screens and depending on which one is active. If iGuidance is active, can't control music. If RR is active, then I can't control iGuidance.
At the moment, the Nulooq navigator does zooming in/out of iGuidance, panning and last voice repeat.
