Results 1 to 6 of 6
Thread: Empty music folders in RR
    Constant Bitrate Outsider787's Avatar
    May 2006
    Just like the subject says: music folders are empty in RR. If I browse to them through windows, there is music in them.
    And this used to work. Then I installed a few programs... don;'t remember everything I did, and now I can't see any of my music in RR.
    Anyone have any thoughts on what I can try to look for?
    Mar 2006
    Colorado, but Canadian!
    are your files not in *.mp3 format? If they arent, make sure that the extensions are added in RR's config.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2006
    Lexington, KY
    Quote Originally Posted by 2k1Toaster View Post
    You can do it in RRconfig under Music - Audio File Types
    or add audiofiles= to your rr.ini with file types that you need.
    May 2006
    All the music files are mp3s.
    When I first installed RR, I could navigate through the music folders in RR, and see all the music.
    But not anymore.
    I will check the rr.ini file tomorrow.
    Jan 2007
    Greece
    I also had this problem.
    The solution is what the guys above said, but be sure .mp3 format is added to your rrconfig.
    May 2006
    Weird.
    You guys were right. The mp3 format was not on the list. Actually the list was empty.
    Anyway, it all works now.
    Thank you!
  1. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 09:31 AM
  2. Replies: 1
    Last Post: 03-04-2006, 07:58 AM
  3. Music Age/Organization
    By Quattro in forum Software & Software Development
    Last Post: 01-24-2006, 06:12 AM
  4. Empty folders!?
    By Rs! in forum Road Runner
    Last Post: 04-30-2005, 10:48 AM
  5. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 09:08 PM
