Xport3 was causing my system to BSOD.
I just set the GPS to Port 0 in RR.
Im using a GM-210 reciever. If I use it with Iguidance only it works great.
If I use RR with it exclusively, it works great...
BUT..
If I use Xport3 to split the ports to RR and IG, it takes 20+ mins to lock on and the updating in IG to my movements is VERY slow.
Any help would be appreciated.
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
well, I want to use it for my flash gauges.
Can you list what ports you using for each?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Is this when resuming froom hibernate? If you open XPort, do you see anything changing on the bottom of the XPort window during the first 20 minutes?
Bet you have bluetooth. Many times you can see the problem driver on the blue screen. Just change your virtual ports to something higher or make sure they don't conflict with other ports that may try to open later, the way some bluetooth drivers do it.
Nothing changes..
I can go into IG and goto GPS info, I see 4-5 sats displaying signal bars, but IG says
SATS 0/7
I have tried using it directly in the back of the PC, or using a hub, no difference.
the GPS is on com 2
I have it split between com 4 and 6
4 is for IG, 6 is for RR.
I have also tried this with a PC and a laptop, same issue.
I have also tried GPSGate to, same issue.
But if I use it without a port splitter, it works fine!!
Would it matter if it was USB 1.1 instead of 2.0? I wouldnt think so as its only 4800bps.
Which version of Xport are you using, as for a long time i used an older version and decieded to try the newest and then had all sorts of probs...went back to old version, rock solid.
Other ppl have mentioned that different versions work better with their setup than the others. Maybe this is your prob??
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Im was using v3 of xport.
Remember, Im using GPSgate right now with the same issue..
without a splitter, it works great individually, but with a splitter, I get no, or sometimes get signals.
All the probs occurring when running win in vmware? Or R you saying that you have also tried it on a full pledged PC/NON Mac with the same issues?
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
