Results 1 to 2 of 2
Thread: A little help gettn flash 2 refresh
    Aug 2007
    hi every1
    well my proplem is that i got my flash playlist working.
    ive split the title an artis into seperate lines i got that work but how do i keep it refreashing all the time. if i change the song in the playlist it doest refreash for me...any help would be nice
    thanks
    here is my code
    Code:
    on frame 5
        playlist = _root.CUSTOMPL.split(chr(13));
        CUSTOMPL = _root.CUSTOMPL;
    on frame 10
        if (oldtr <> _root.TRACKNUMBER) {
            gototrack = "SETLIST;" + _root.TRACKNUMBER;
            if (_root.cl == 1) {track.gotoAndPlay(1);}
            tr = _root.TRACKNUMBER - 1;
            oldtr = _root.TRACKNUMBER;
        myColor = new Color (tr4);
        myColor.setRGB(parseint(_root.col));
        tt1 = substring(playlist[-3 + tr],4,40);
        tn1 = -2 + tr;
    	ts1 = tt1.split("/");
        tt2 = substring(playlist[-2 + tr],4,40);
        tn2 = -1 + tr;
    	ts2 = tt2.split("/");
        tt3 = substring(playlist[-1 + tr],4,40);
        tn3 = 0 + tr;
    	ts3 = tt3.split("/");
        tt4 = substring(playlist[0 + tr],4,40);
        tn4 = 1 + tr;
    	ts4 = tt4.split("/");
        tt5 = substring(playlist[1 + tr],4,40);
        tn5 = 2 + tr;
    	ts5 = tt5.split("/");
        tt6 = substring(playlist[2 + tr],4,40);
        tn6 = 3 + tr;
    	ts6 = tt6.split("/");
        tt7 = substring(playlist[3 + tr],4,40);
        tn7 = 4 + tr;
    	ts7 = tt7.split("/");
    on frame 13
        t1 = substring(ts1[0],0,40);
        a1 = substring(ts1[1],0,40);
    	tn1 = -2 + tr;
        t2 = substring(ts2[0],0,40);
        a2 = substring(ts2[1],0,40);
    	tn2 = -1 + tr;
        t3 = substring(ts3[0],0,40);
        a3 = substring(ts3[1],0,40);
    	tn3 = 0 + tr;
        t4 = substring(ts4[0],0,40);
        a4 = substring(ts4[1],0,40);
    	tn4 = 1 + tr;
        t5 = substring(ts5[0],0,40);
        a5 = substring(ts5[1],0,40);
    	tn5 = 2 + tr;
        t6 = substring(ts6[0],0,40);
        a6 = substring(ts6[1],0,40);
    	tn6 = 3 + tr;
        t7 = substring(ts7[0],0,40);
        a7 = substring(ts7[1],0,40);
    	tn3 = 4 + tr;
    on frame 16
        if (_root.cl == "0") { gotoandplay(25)} else {
            gotoAndPlay(1);
        if (cl <> _root.LISTPOS - 1) {
            tr = _root.LISTPOS - 1;
            cl = tr;
            gotoAndPlay(10);
    on frame 20
        if (_root.CUSTOMPL <> CUSTOMPL) {
            gotoAndPlay(3);
        } else {
            gotoAndPlay(10);
    on frame 30
        gotoanplay(20);
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm sorry I can't be of much help with the flash portion itself -- but basically, you can do one of two things:
    1-Clear _root.CUSTOMPL immediately after parsing it, then monitor it. When it's set again, you should again parse it, then clear it. This will make sure you always keep the list up to date.
    2-Request the updated list everytime you issue a command that you know will change the playlist (ADD1, CLEARLIST, SELECT/+, MINUS1, etc), this is probably more efficient but requires organization so you don't miss any times you were supposed to reload the list after a command (that affects it) is issued. The command: fscommand("getpl") will set _root.CUSTOMPL with the most up-to-date info, so you can parse the variable immediately after issuing the getpl command.
    Ride Runner RR's Myspace
  1. Replies: 4
    Last Post: 12-04-2008, 02:29 PM
  2. Replies: 33
    Last Post: 03-28-2008, 03:18 PM
  3. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 08:23 PM
  4. sending keystrokes to flash?
    By Nitrov8 in forum Road Runner
    Last Post: 04-07-2006, 01:51 AM
  5. Replies: 24
    Last Post: 03-03-2006, 01:36 PM
