no one knows? ok maybe someone knows how to set the external_gps.skin (i think thats the name of the file) to move the gps window and i can just have it try and move the gps window to -1280 so it should show up...
I'm using iGuidance and got RR to load it up no problem.. got the GPS working and everything.. BUT i'm running all this off a laptop and using the touch screen as a second screen.. in the general.ini for the skin i have it set to move RR over to the 2nd screen and it works great BUT when i try and load the iGuidance for some reason RR offsets that the same amount as RR is offset
meaning
monitor 1 is 0-1279 pixels across and monitor 2 is 1280-2080
so if i set RR to pop up at 1280 it fills up the whole 2nd screen but then RR tells iGuidance to pop up at 2560 (1280+1280). I tried it with a lower settings like 100 and it start RR 100 pixels in and then iGuidance is another 100 pixels..
I also tried 4 different skins and they all do the same thing
heres a screen shot.. anyone know what to do to solve this? i've tried to search.. but didnt find anything.. =P
this sounds like a bug... are you using IGNative options ? could you try to turn it off ? it shouldn't be doing that... I'll have a quick look at it.
EDIT: I've verified, the window positioning when using ignative should be relative to RR's screen not the desktop (as when not using ignative) -- a negative position in the A definition should fix it for now, as would disabling ignative. This still needs to be fixed.
Ride Runner RR's Myspace
ok i'll try both of those suggestions =)
