Results 1 to 5 of 5
Thread: Visualization behind window
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Okay I've searched extensively on this and followed all the advice I can find and it's still not working. I'm trying to get my visualization to show in front of RR without using the clip feature (which works but is kludgy). I'm running the current version of RR (4-17-07), Shock 3.0 skin (I'm modifying it), and Sexy Spectrum Analyzer vis. The vis shows up fine via button press when I move it off the RR screen.
    My rr.ini includes:
    visuname=attachanalyser
    This is my menu.skin:
    MEDIACAR Skin
    MEDIACAR menu Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    /C01,0,307,800,100,
    A22,000,307,800,100,000,000,100,
    B22,692,000,106,80,"VISU",
    / COMMON CONTROLS
    B,000,000,115,80,"MENU",
    B,115,000,115,80,"AUDIO",
    B,230,000,115,80,"VIDEO",
    B,345,000,116,80,"GPS",
    B,461,000,116,80,"LAUNCH",
    B,576,000,116,80,"SKIN",
    B,000,400,100,80,"VOL-",
    B,100,400,100,80,"VOL+",
    B,200,400,100,80,"MUTE",
    B,300,400,100,80,"PREV",
    B,400,400,100,80,"PLAY",
    B,500,400,100,80,"NEXT",
    B,600,400,100,80,"GAMMA",
    B,700,400,100,80,"LOAD;exit.skin",
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES,
    Tooltip;LABELALIGNMENT
    L01,005,04,105,40,255,255,0,24,"Arial:B","TIME","C ENTER"
    L02,015,37,85,15,200,200,200,12,"Arial:B","DATE"," CENTER"
    L02,713,04,37,10,200,200,200,9,"Arial:B","=Load:", "RIGHT"
    L02,757,04,35,10,255,255,000,9,"Arial:B","CPU","LE FT"
    L02,713,16,37,10,200,200,200,9,"Arial:B","=MB:","R IGHT"
    L02,757,16,35,10,255,255,000,9,"Arial:B","MEM","LE FT"
    L02,713,28,37,10,200,200,200,9,"Arial:B","=CPU:"," RIGHT"
    L02,757,28,35,10,255,255,000,9,"Arial:B","MBM01"," 0C"
    L02,713,40,37,10,200,200,200,9,"Arial:B","=Mem:"," RIGHT"
    L02,757,40,35,10,255,255,000,9,"Arial:B","MBM02"," 0C"
    / END COMMON CONTROLS
    L,77,447,136,63,255,255,255,20,"ISOCPEUR","VOLUME" ,"LEFT"
    L,9,70,750,28,255,255,255,18,"ISOCPEUR","TRACKNAME ","SCROLL-LEFT"
    END
    Nov 2006
    Everett, WA
    This is my intended look. Clicking on the system status area brings up the visualization.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    try leaving say "notepad" open, then set visuname=notepad, run RR and see if by pressing the VISU button notepad gets embedded.. if so, it's most likely a wrong window name or the visualization is being *****y with you
    EDIT: WTF ? the B word is censured? hahahaha it's even in the dictionary! hahaha
    Ride Runner RR's Myspace
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    I was going to start to play with that vis but i was going to use a different window name based on this:
    Quote Originally Posted by 01black_ac View Post
    Thanks DiNASTY, I'm going to try that string out tomorrow (can barely keep my eyes open right now).
    For anyone interested in embedding vis_satan (sexy attached analyzer) the window title to add to rrconfig.exe under "Other (Window Title)" is:
    !attachanalyser!Classic Stereo Specturm Analyzer
    Yes, it's misspelled. It needs to be, that's the correct window title.
    Hope that helps someone out there.
    '01
    There seams to be a cofusion (i know i'm confused) as to wether "sexy attached analyzer" and "vis_satan" are the same.
    Let us know what progress you make..
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    Nov 2006
    Everett, WA
    Ahhhh I figured it out! The correct syntax is "visuname=!attachanalyser". It's kinda misleading because it creates and destroys the process whether you spell it correctly or not. Yay.
    From what I see, they're one and the same. The filename is "vis_satan.dll", but it shows up in Winamp as "Sexy Attached Analyzer". The process in Winspector Spy is "attachanalyser".
  1. Alpine City Cruise
    By Hell-Stopper in forum RR Skins
    Last Post: 02-22-2007, 11:05 PM
  2. dancing figure in visualization window?
    By llajumpvid in forum FrodoPlayer
    Last Post: 03-31-2006, 04:47 PM
  3. Hide window frame of winamp visualization window
    By stepir in forum Road Runner
    Last Post: 12-28-2005, 01:02 PM
  4. iGuidance 2.x auto-run shortcut
    By ziggyrama in forum GPS
    Last Post: 08-13-2005, 07:05 PM
  5. Visualization Window Pop-up
    By Quattro in forum RR Bug Tracker
    Last Post: 02-28-2005, 04:15 PM
