Results 1 to 10 of 12
Thread: iGuidance v2.1.2 into RR: Window problem
    sjj
    sjj is offline
    Dec 2006
    Hello
    I have install IG on my carpc all works fine, but when i open RR an click on GPS my IG software open in full window and hidden my RR interface.
    I RR.ini setup is:
    IGNative=true
    igautosw=true
    lastscreenswitchtime=3
    I had change patch to IG and set et to External.
    What can I try, thanks...?
    /Steffan
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    sjj
    sjj is offline
    Dec 2006
    MGD: Yir I have, but it still not work.
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    Make sure you have those lines in RR.ini
    gpsmode=2
    gpspath=C:\Program Files\iNav\iGuidance\iGuidance.exe
    gpsname=iGuidance
    sjj
    sjj is offline
    Dec 2006
    Okay I took your 3 lines and changes IGNative=true to IGNative=false now it works. Thank you many times MGD.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I'll have to add a check for this too...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Mar 2005
    I have tried all the possible settings and for some reason it will not embed the i guidance 4 window.
    any suggestions?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by QuagmireMan View Post
    any suggestions?
    what is wont embed?
    open the program but not make it look like part of RR, or nothing happens at all?
    If the first, your window title is probably not correct. What is it?
    If the second, then your exe path is probably not correct. What is it?
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    where i goto the gps skin from the menu, it loads the application iGuidanceUMPC.exe but it does not embed the window.
    gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
    gpsname=iGuidance
    Mar 2005
    Could there be a problem, since I am embedding an app in another skin?
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Alpine City Cruise
    By Hell-Stopper in forum RR Skins
    Last Post: 02-22-2007, 11:05 PM
  3. Iguidance 3 and RR
    By tsx004 in forum GPS
    Last Post: 10-21-2006, 04:17 PM
  4. How to embbed any Application in RR ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 01:35 PM
  5. Embedded iGuidance Window Size?
    By All4Sky in forum MediaCar
    Last Post: 08-27-2004, 09:00 AM
