Results 1 to 10 of 19
Thread: Mouse commands
    Nov 2005
    Missouri
    Mouse commands
    Is there any such thing?
    I use keyboard commands such as "SENDKEY;^{UP}","Page Up" with RR buttons to control things like Street Atlas and RR Earth.
    What I need is a mouse command, specifically mouse scroll up/down.
    I have a skin with the interactive weather map at weather.com. I can zoom in by clicking the screen, but I cant scroll out without using the mouse. I'd like to try creating a button with mouse scroll out to control this function.
    So are there any such commands? Will RR recognise them?
    Thanks...Paul
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's no current mouse "emulation" commands in RR (like the ones for the keyboard) mainly because it's hard to tell the positioning or the placement of the mouse over the window (and which window), without knowing where exactly it is embedded.
    RR Earth however, has commands to set the zoom and tilt levels without using the mouse.
    Ride Runner RR's Myspace
    Nov 2005
    Missouri
    Quote Originally Posted by guino View Post
    Guino,
    I see your point, For what I had in mind it would certainly be necessary for the mouse to be over the correct area of the display.
    Just thinking out loud (dangerous I know)
    Would: The ACTIVATE command, followed by a command to position the cursor (assuming it existed), followed by the mouse command (assuming it existed) work?
    ...Paul
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    If you are using the interactive map I think that you are, there is a scroll bar in the top left of the window. Be it pretty small, but it will let you zoom in and out.
    When I get a chance to mess with it, I am going to see if I can send some control-Clicks with an AutoIt script, to be able to control the buttons on the map, with Road Runner buttons. This should work, as the interactive map can not be resized, and the coordinates will be from the top left of the map, and not the top left of the Road Runner skin.
    My Fiero Build Thread
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by pshadwick View Post
    Guino,
    ...Paul
    Possibly would work, right up until that program (or outside application) throws in a window on top of it cause RR to click on something it wasn't supposed to, which could either do nothing, or do something you didn't want it to do.
    Nov 2005
    Missouri
    Quote Originally Posted by JohnWPB View Post
    Unfortunatly the window does not resize, to get the animation controls I had to move the window way (-66 I think), so I lose the scroll bars off the top.
    ...Paul
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    i can whip up something in autoIT pretty quick that will do this.
    Ill also assume for now that the control u need to activate is in the center of the screen, so what will happen when click the button is it will first move your mouse to the center of the screen and make one click, then scroll the mouse wheel up or down.
    If this is what u want let me know and i ll post it up.
    beer replenishment fund
    mp3car live search
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Darn...to late. thought that I might have another small challenge to pursue...unless LS chicken's out...LOL
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Nov 2005
    Missouri
    Quote Originally Posted by liquid_smoke View Post
    That sounds just what I what looking for.
    Thanks...Paul
    Aug 2003
    Chicago
    here you go.
    This version is configurable so if you need to change anything its supereasy.
    place the unzipped files into your skins directory.
    Add this line to your ExecTBL.ini
    Code:
    "mousewheel_UP","Run;$skinpath$\mousewheel.exe|300 400 up 3"
    "mousewheel_DOWN","Run;$skinpath$\mousewheel.exe|300 400 down 3"
    the application receives commands from RR as to what position to move the mouse to, what direction to scroll the wheel and how many times to scroll it.
    Using the First line of code above as an example.
    300 is X position
    400 is Y position
    up is direction
    3 is number of times to scroll
    each option should have a space between them and all options must have a value or it wont work.
    Create a button that uses "mousewheel_UP" or "mousewheel_DOWN" as its button code.
    Customize and create buttons as needed.
    Attached Files Attached Files
    mp3car live search
  1. Girder, RR.GML, and mouse input
    By Sidewalksalvage in forum Road Runner
    Last Post: 06-18-2007, 01:59 AM
  2. SpeakEasy Voice Recognition - Beta 1
    By ruairi in forum Road Runner
    Last Post: 08-23-2006, 12:12 AM
  3. PS2 3 Button(Rotary Wheel) Mouse Properties?
    By nFiniteTuning in forum Input Devices
    Last Post: 03-12-2005, 10:43 PM
  4. Replies: 4
    Last Post: 02-15-2005, 08:13 AM
  5. Smallest Touch PAd Mouse... or Shuttle Mouse QUESTION!!!
    By Boozshey in forum General Hardware Discussion
    Last Post: 01-23-2005, 03:38 AM
