Results 1 to 9 of 9
Thread: Blank screen after a few sec of video
    Apr 2007
    I am using WMC and it plays the video but i get a black screen after the video plays for a few sec when i move the mouse the video returns. The sound continues the whole time. It must be some setting i missed somewhere any suggestions?
    Godspeed,
    ~Peter
    Apr 2007
    ok i disable video auto hide and it seems to have fixed it but is that what that setting is suppose to do? I assumed it was for the controls at the bottom
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Do you have global transitions enabled in your RR config?
    If the answer is yes then that is your problem,you need to disable the feature in the ini and add the transition effects to each individual .skin file instead but dont add a transition to you video .skin or dvd .skin.
    Take a look at my posts in this thread for more info and the command to add to the .skin files = DVD goes black
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    I knew about it but i didnt know to to fix it so i just disable transition all together. This is something that is been around for quite awhile since all i do in my car is watch music vid. i guess i should have brought it up.
    Apr 2007
    I Love U!
    Thanks!
    ~Peter
    Nov 2005
    Midlands
    @ tn6478, yes you remove the line Transition= from the RR.ini and if you still want transitions in your skin you need to go into each .skin file and add EFFECT= followed by the transition number of your choice,the upside to this is you can now set a different transition style to each screen instead of the same 1 for all screens that the global setting provides.
    @ Peter,i'm glad i could help.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok folks..no need to disable the global transition in rr.ini.
    just disable the "EFFECTOUT", in the video skin..This is what is causing the problem, not the "EFFECTIN"
    just put this in the video skin
    /EFFECTOUT=-1
    Nov 2005
    Midlands
    I'm not familiar with those commands,are they new,either way thats good news.
    Apr 2006
    Greece
    yes.. the new version is using blue zx3's advanced transitions effects..
  1. in this video, what on screen keyboard is it?
    By Snortonnorton in forum Software & Software Development
    Last Post: 08-22-2007, 09:32 PM
  2. blank screen occasionally but windows starts up ??
    By CoupeE46 in forum General Hardware Discussion
    Last Post: 05-24-2007, 04:19 PM
  3. 2005 Land Rover LR3 - How to Input Video to Nav Screen on MOST Bus
    By joedavenport in forum General Hardware Discussion
    Last Post: 01-27-2007, 08:02 PM
  4. no video in full screen mode
    By arise360 in forum LCD/Display
    Last Post: 12-02-2004, 03:44 PM
  5. Video screen squashed.
    By ShawJohn in forum LCD/Display
    Last Post: 11-30-2004, 02:55 AM
