Hi,
There is two issues in the new build.
1. when you select Radioshark in RR Config it defaults back to HQCT whenever you access RR Config so it always has to be reset.
2. There are 2 config files RR Config.exe (new) and RRConfig.exe (old). Is the new one supposed to replace the old. If so then you need to make the same name.
