Does any music play ? did you by any chance register winamp.dll and then moved it somewhere ?? are you able to play the same files in winamp alone (outside RR) ?
Ride Runner RR's Myspace
i didn't move the dll. I can't play the files in or out of rr while i can play others.
1998 Camaro Worklog Starting over, New setup for 2010
My Fiero Build Thread
ok well then i guess it'd be a winamp issue since i ripped the cd's and they play perfect in window media player.. any ideas on that? they used to play in winamp. I'm using 2.95
Are they .mp4?
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
guess he ripped some cd tracks
the ripped tracks play fine on WMP but not on winamp
is that the question?
you ripped it to .wma or .mp3? constant bitrate or VBR? wich bitrate?
as john said, the more info, the better
[]s
ripped as .mp3 at 192kBps
They work perfect on windows media player but not winamp.
I have version 2.95 and have downloaded it several times to make sure it's not corrupt and tried it on different computers without any problems. To top it off tonight i installed winamp 5.3 and it works perfect, but i'd like to not use it because of the performance side effects.
