for Web Addresses there is a specific command you should use that loads the OSK and opens the browser on it: "WEBURL" -- are using this ? and if so, on which browser ?
Edit: Just tried it on Firefox and it worked.
Recently while working on my skin I noticed that RR now freezes when trying to enter a web address using the RR OSK. NOt sure why, I hardly ever use it so I dont really car a whole lot, but others may.
Any ideas
New Age Garmin - Skin for RR
Ride Runner RR's Myspace
actually Guino i noticed that when using the web plugin and opening the OSK, the skin is quiet "strange"..it will not accept flash transperancy at all.. it would just play flash with a white background..does not happen when calling the same OSK with standard RR command
Yup, using the weburl command. That is when it happens. The numosk works great when using it with the tripmeter or gasprice finder.
@thunderstick: Which skin/browser are you using ? Are you using the web PLUGIN or the built in web function ?
@Nomader: I may have to recompile the web plugin with the latest flash to prevent the border issue -- this is based on a much older code of RR and definitely could use some updating.
I am using my own skin New Age, this uses the built in web function with internet explorer.
Tried it in the CFX skin as well just freezes up. I switch the URL command to the APPOSK command and everything works fine that way. And looking through a lot of different skins, most are using the APPOSK command to input a URL.
what version of IE are you using ? I'll have to check this out.
