Because of this, I have Winamp setup "Read metadata when files are Played". With the ON LOAD option, I was not seeing artist names in my playlist. Is there a way for me to get artist and title tags without taking them from Winamp?
I've also been using strictly On-the-fly playlists, however when I use the SAVELIST command, it does correctly create a complete playlist, including songs that were added with ADD1 and SELECT+.
The SELECT+ command appears to behave just like ADD1 except that it works on folders.
Even though I have Winamp set to just show %title% in its playlist, when a song gets moved into the playlist with SELECT+ or ADD1, Winamp
displays the complete filename of that song instead of its title. Clicking on it in RR will not play it (the highlight in RR and Winamp playlists drops down and plays the next available "non-added" song in the list).
Toggling the sort button produces very interesting results. When sorted by artist-title, The Winamp playlist correctly sequences the songs, but the RR display only displays the title for the added songs (whatever is after the " - " in the filename). When sorted by title, Winamp is using the complete filename for the added songs and just the title for the existing songs. Consequently, the added songs end up in the wrong place in the list.
I believe this all has to do with the metadata setting in Winamp and the fact that added songs are not processed correctly. What alternatives do I have to get artist and title tag data, while being able to sort? My directories are usually under a few hundred songs each and I use them instead of playlists to organize my songs.
