Results 1 to 9 of 9
Thread: voice recognition on resum
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Hi,
    Heres a strange one, when i hibernate from road runner, when it resumes the voice recognition stops...
    that is until i goto control panel and select speech (bear in mind i do not change any of the settings whatsoeva) but for some reason it just starts working again!?
    This happens everytime. When the machine is restarted its fine, until of course i hibernate again
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    what are you using for voice recognition ? navivoice ? the voice recognition plugin ?
    Ride Runner RR's Myspace
    Nov 2006
    Wales, UK
    Quote Originally Posted by guino View Post
    im using a program called Audiomatic, gives alot more options than the other voice recognition progs ie: it can run autoit scripts with voice commands etc.
    thanks
    CarPuter Progress:
    Nov 2006
    Wales, UK
    I was just thinking, as i clicked reply...
    what if it just added the 'speech' utility from control panel, and add a button to launch/embed it?
    that should do the trick?
    CarPuter Progress:
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Run your voice app, then try hibernating without having RR running... my guess is that when you resume, it won't work (meaning it's not RR related).. if that's the case, my best suggestion would be to close and re-open the application on hibernate/resume.. to re-open is as easy as using a command line to execute it in Exectbl.ini:
    "ONRESUME","RUN;<PATH TO YOUR APP.EXE>"
    To close it, you could try finding a command line and use the same as above with the "ONSUSPEND" event, or you can try to close it with the "CLOSEWINDOW" Command -- if this app has a window that can be closed to shut it down.. look up the command in skin commands.txt.
    Nov 2006
    Wales, UK
    Your right, it does the same without Road Runner
    its a strange one
    ill try your advice, do you know what the command would be to run the windows speech, if i embed it?#
    thanks
    CarPuter Progress:
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I honestly don't know.. but if you're going to use the Windows Speech, you're better off trying the voice plugin for RoadRunner or Navivoice -- both of which use/improve upon the windows speech (and possibly is what Audiomatic may do as well).
    Nov 2006
    Wales, UK
    Im pretty sure your original plan will work by closing before hibernation.
    Thanks for the help Guino.
    CarPuter Progress:
    Nov 2006
    Wales, UK
    If I launch my applications from the LAUNCH folder, i use this with the E36 skin, all the programs i need load via the LAUCN skin, and I can cycle through the screens individually, without closing them
    If i use those commands, is there a way of getting them to re-load so that they remain embeded the way they were before hibernation? rarher than just loading...
    Cheers
    CarPuter Progress:
  1. Customer question about voice recognition
    By Zip-Lock in forum StreetDeck
    Last Post: 09-13-2007, 02:41 PM
  2. Voice recognition broken on 1.0.8.1
    By spaceskater in forum StreetDeck Bug Reports
    Last Post: 06-22-2007, 03:25 PM
  3. SpeakEasy Voice Recognition - Beta 1
    By ruairi in forum Road Runner
    Last Post: 08-22-2006, 11:12 PM
  4. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  5. Voice recognition problems. WinXP/Navivoice.
    By mikebaz in forum Software & Software Development
    Last Post: 08-07-2005, 03:44 PM
