Results 1 to 2 of 2
Thread: problem with winamp vol and radio spectrum analizer
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    hi to all, is possible to set winamp vol to zero when i open some sub-menu?(example radio) and then reset to the maximum once that within in skin music? I have applied a plugin that it allows me to visualize spectrum analizer also for the radio through winamp, only that that generates an annoying echo
    the plugin is:
    thank you and
    sorry for my bad english
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can set the buttons to do that.. like "AUDIO||SETVOL;Winamp;255" -- read more in skin commands.txt
    Also, that plugin is already used as an option for radio in RR.. and knowing how it works, I believe you do NOT want to mess with winamp's volumes -- what you want is to MUTE/UNMUTE the >>AUDIO LINE<< used to playback the audio -- which you can also do using the MUTE command also described in skin commands.txt
    Ride Runner RR's Myspace
  1. Indexing music in Failed
    Last Post: 07-07-2007, 12:19 PM
