Results 1 to 2 of 2
Thread: wave volume problem
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    wave volume problem
    for some reason everytime i start rr my wave volume is 0
    in the rr config i have mapped to master vol, this has only started to happen was working fine till now.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    try looking for those and setting/adding them (when not already present) in RR.INI:
    mapmastervolume=0
    fadeinvolume=false
    If you already have those in place, open winamp and switch the Output plugin from Waveout to DirectShow or the other way around, then try again. If anything, try uninstalling and deleting Winamp's folder then re-installing.. this is most likely a setting issue, but you can try a different winamp version.
    Normally this problem just happens when not using the mastervolume map or when screwing with winamp's settings.
    Ride Runner RR's Myspace
  1. Replies: 6
    Last Post: 02-20-2007, 02:13 PM
  2. David:AC 97' Sound Card Problem
    By bishooman in forum Centrafuse
    Last Post: 11-14-2006, 08:55 PM
  3. Volume problem
    By J-spec in forum Mobile Impact
    Last Post: 07-31-2005, 06:23 PM
  4. Laptop and low sound volume problem
    By Hark in forum Car Audio
    Last Post: 07-13-2005, 04:49 PM
  5. Adjusting Wave & Main Volume Options??
    By xtreme_db in forum FrodoPlayer
    Last Post: 09-03-2004, 09:02 PM
