Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 84
Thread: RR 09-30-2007 ... HD Radio & some more..
  1. #41
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Ok, it's the GPS. I unplugged it, started RR, it ran for several minutes just fine, played some tunes, no problem. Plugged in the USB GPS cable, 1:06 frozen. Cut power, unplugged GPS started it again and RR ran just fine all the way home.
  2. #42
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    Quote Originally Posted by TimmyM View Post
    After a couple of months doing nothinh with my carpc I decided to upgrade some things and one of them was RR. Unfortunately now I'm having the same problem as described above. Removing the GPS unit is not my ideal solution so I hope there is a fix for this. In the meantime I will try some things out to see if I can discover it.
  3. #43
    Jul 2006
    I was having very similar problems. Delete ziplocator.dll. This will force RR to use it's internal zip locator, and you should be good to go.
  4. #44
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by barnyard View Post
    Well what the heck is that even used for?!?!
  5. #45
    Amsterdam
    I don't even have such file in my RR directory so I can't remove, should it be there by default?
    edit:
    changed localdatacaptureinterval=1 to localdatacaptureinterval=0 and problem seems to be solved.
  6. #46
    Jan 2007
    Greece
    I'm having some problems with this version.
    I have manually updated to 30/9/07 from 11/4/07 (just copied the new files)
    The problems are:
    1)Winamp doesn't seem to work. I make a playlist but when I push PLAY nothing happens
    2)If I restart RR the playlist is gone!
    3)The TV skin doesn't work. I listen to the sound but there is no video frame. (I just see the background)
    4)The ADD ALL command for songs doesn't seem to work.
    Everything works fine when I go back to 11/4/07
    Any thoughts?
  7. #47
    Jul 2006
    The way I understand it is that RR has a built in locating function that gets your current City, State, Zip code, etc. from your current GPS coordinates. The ziplocator.dll is supposed to make it faster for some computers to search the zips.dat file. In my case the internal function works, while ziplocator.dll locks up RR.
    @partybuster:
    do you have a zips.dat file? If so, try downloading zipslocator.dll from http://www.kompassist.co.uk/ZipLocator.zip. Maybe it'll work for you.
    Good luck guys!
  8. #48
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by agiorgitis View Post
    The problems are:
    Any thoughts?
    RUN THE NEW CONFIG UTIL!! Will solve just about all those!
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  9. #49
    Aug 2003
    Federal Way, WA
    Wel that was the flippin' problem all right! Renamed the screwy thing, plugged back in the GPS and now everything is hunky dory.
    Thanks a lot for the help!
    TIm
  10. #50
    Jul 2006
    Sweet! Glad I could help.
    BTW, did you set localdatacaptureinterval back to 1?
  1. HD Radio
    By pcullin in forum Car Audio
    Last Post: 09-01-2008, 12:31 PM
  2. RR + Mediaengine - Tv + FM radio ??!?!?!
    By 12345car in forum Newbie
    Last Post: 05-13-2006, 09:13 PM
  3. Replies: 7
    Last Post: 02-09-2006, 08:42 AM
  4. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  5. Radio for RR in CH
    By johnwrx in forum General Hardware Discussion
    Last Post: 06-04-2005, 05:43 AM
