MCI error 261 and 263
Hi all,
I have some troubles with RR on my car PC when trying to play video. The screen remains black and the timings are all 00. I get the following errors (debug) :
Code:
09.10.2007 10:48:35: Executing: VIDEO
09.10.2007 10:48:37: MCI Open Error: 263
09.10.2007 10:48:37: MCI Size Error: 261
09.10.2007 10:48:37: MCI Play Error: 263
09.10.2007 10:48:38: MCI Size Error: 261
09.10.2007 10:48:39: MCI Size Error: 261
09.10.2007 10:48:40: Executing: play
09.10.2007 10:48:40: MCI Play Error: 263
09.10.2007 10:48:40: MCI Size Error: 261
09.10.2007 10:48:41: MCI Size Error: 261
09.10.2007 10:48:42: MCI Size Error: 261
09.10.2007 10:48:43: MCI Size Error: 261
09.10.2007 10:48:44: MCI Size Error: 261
09.10.2007 10:48:45: MCI Size Error: 261
09.10.2007 10:48:46: MCI Size Error: 261
09.10.2007 10:48:47: MCI Size Error: 261
09.10.2007 10:48:48: MCI Size Error: 261
09.10.2007 10:48:49: MCI Size Error: 261
09.10.2007 10:48:50: MCI Size Error: 261
09.10.2007 10:48:51: MCI Size Error: 261
On my desktop PC it is working fine.
The Carpc has a nlited Xp SP2 version. I don't have wmp on it (thought it was not necessary while using mplayerc and divx codecs). If I launch mplayerc on the carpc the video is working :confused:
Any ideas
Thx
This typically is a file issue -- try loading different files/video onto the video player. Or try a video fixer application.
I came across an MPG file with this problem and I was able to FIX it using two tools in sequence:
1-FIXMPG1.EXE <FILENAME>
Which creates separate video (MPV) and audio files (MP2)
2-MPLEX1.EXE <FILENAME>.MPV <FILENAME>.MP2
The result was almost 2Mb bigger than the original file (of 38Mb)! But it looked like it was more in sync than the original file as well.
Here are the tools:
http://www.geocities.com/SiliconValley/4942/fixmpg1.zip
http://members.aon.at/johann.langhof...ex1/mplex1.zip
