Results 1 to 10 of 12
Thread: RR laggy- How to optimize RR for a slow system and what skin to use
    May 2007
    I am currently running RoadRunner with Simplistique using Winamp for audio and Mapmonkey for GPS.
    This setup runs on a C3 800mhz CPU with 512 MB RAM and a 40GB 2.5" HDD and is set in my Opel Corsa in Chennai, India,
    The OS is nlited Win XP stripped down to ~200MB with most useless services killed.
    My windows startup is around 15 seconds from the POST screen so I presume the OS is fairly optimized
    The problem I am facing is that Roadrunner seems to be very laggy.
    -If I click on the music icon on the home screen, it takes 2+ seconds for the music screen to come up
    - If I click on the vol up/down buttons, the actual adjustment happens after 2+ seconds
    - Searching for music is extremely laggy and does not emulate the "J" hotkey on winamp, i.e. it won't find a song until i type in the exact name
    Which brings me to my questions:
    a) Is there a skin that is optimized for relatively low end configurations
    b) Are there any config edits in RR that would help me improve the response times
    I could do a trial-and-error on different skins and setting combinations to resolve this, or dig into the collective knowledge base of mp3car users :-)
    The latter is obviously preferred
    Thanks for the help folks..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    For low end systems, I'd recommend:
    -Playing with the Fastmode= setting in RR.INI (try: -1, 0, 1 and 2 to see)
    -A Skin that does NOT use FLASH, and is the same size as your screen's resolution
    -Disable transitions: transition=-1 in RR.INI
    -Disable gestures: usegestures=false in RR.INI
    -Use Winamp 2.95 -- remove any plugins from it that you do not use
    -Do NOT use the GPS setting in RR itself, leave that only to Mapmonkey
    There's no reason why RR should lag 2 secs to control volume -- even my Pentium 200 Mhz with 64Mb RAM and 4Gb HD running Win98SE has immediate effect over the volume.
    Ride Runner RR's Myspace
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    PreLoad your skin files in rr.ini to avoid the menu lags.
    Try mapping your volume control in rrconfig to main, wave, etc and see which works best. (this method is for weak sound cards)
    You can try my skin, it runs on a similar platform (1ghz via, 200 MB nlited embedded OS) and is very fast.
    May 2007
    thanks guys..I'll try out both the suggestions over the weekend
    The only thing that I now need is a tip on how to get the song search function in RR to emulate the J hotkey on winamp
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    How to speed up Road Runner on a slower system
    There are also some other things to do to help RR run smoother on a slower system. There is a FAQ on this HERE
    My Fiero Build Thread
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Remove any antivirus, popup blockers, firewalls and adblockers. Since you will more than likely not be using internet too much in your car you do not need this stuff. Do a virus check on a different computer on the files before you add them to your carputer and you will be fine.
    All these things take a significant amount of memmory and really are not need on unconnected computers.
    I will probably get a lot of flac from this, but really think about it. How is your computer going to get infected if there is no means of transporting the virus to your computer.
    New Age Garmin - Skin for RR
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    @ThunderStick
    Did you completely read his first post, he said that he was already running a very stripped down xp, so I woud pretty much assume that he doesn't have any of that running anyway...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jan 2006
    Is this the latest version of RR
    I have the same issue with volume... takes a lifetime to respond on a via epia EN 1.5
    .... been tearing my hair out to figure out why.
    Jan 2006
    BTW
    when i hit the volume buttons, and volume buttons "only" the CPU usage goes up to about 80 for RR, not winamp.
    Any hints?
    Aug 2006
    West Allis, WI
    @ThunderStick
    I assume nothing... Stripped down may mean he is sitting in front of his computer with only his shorts on and playing a heated game of leisure suit larry on windows xp.
