Results 1 to 4 of 4
Thread: RR High Idle CPU
    Jun 2006
    Richmond VA
    RR High Idle CPU
    I'm currently idling at nearly 90% cpu in RR, latest version, using minlogon, booting directly into RR as shell. Not sure what caused this recent change, and i'll look into it more tomorrow, but are there any suggestions as to where i can find the problem?
    Brett
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    First thing that comes to mind would be a possible flash issue. And you prob won't get too much help, because you need to be a little more detailed, what skin, which lastest rr version(some ppl think they have the lastest and don't), winamp ver...ect the more detail and things that you've noticed or did prior to the cpu usage. will get you much better help.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2006
    Richmond VA
    Thanks for the tips. I downloaded the installer from the download distributor just two days ago, but i'll double check the version. I'm using DigitalFX without a flash logo. Winamp 2.95. Prior to this I followed (I think it was your writeup) about speeding up RR, so i'll go through that and see if anything changes when I undo those. And, as mentioned, I made the switch to minlogon and RR as shell.
    Brett
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Nope, That write up was JohnWPB, and wish I had did those things much earlier. It just speeds along now...
    I heavly believe that there is more than just the flash logo thats flash in that skin...wouldn't hurt to dbl check that you have flash installed just to be on the safe side. That is about the most single reason someone would see an idle like that, and did you check the high cpu usage FAQ?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. RR Config Updated - Blue ZX3
    By Blue ZX3 in forum Road Runner
    Last Post: 06-09-2011, 05:17 PM
  2. Replies: 19
    Last Post: 12-15-2006, 11:34 PM
  3. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  4. High CPU Load with Freedom-Skin
    By tobiasmarx in forum Road Runner
    Last Post: 10-24-2006, 07:08 PM
  5. Occasionally winamp uses almost all the cpu slowing down RR
    By Arathranar in forum RR Bug Tracker
    Last Post: 03-22-2005, 12:38 AM
