Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Has Anyone Using RR/DigitalFX/New RRConfig/iG4 Gotten Music to Pause?
  1. #11
    Jun 2002
    Virginia
    Quote Originally Posted by fixerofallthing View Post
    I have it working fine in DigitalFX
    Are you using RR (9/30), DigitalFX(9/9), RRConfig (10/10) and IG4?
  2. #12
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    have you checked the skin exectbl.ini to see if you have a duplicate pause setting by chance? duplicate entries tend to cancel each other out in RR
    Live mp3Car Facebook Chat
  3. #13
    Low Bitrate TonyWare's Avatar
    Jun 2007
    Ottawa Canada
    Thumbs up
    Quote Originally Posted by Sonicxtacy02 View Post
    Bingo! Thats the issue (thank you!).
    Found an extra set of pause related lines in the exectbl.ini under the rr directory. Don't ask me how they got there, I don't remember if I put there there myself while I was playing around or it came with it. The only pause-related lines now exist in the exectbl.ini under the DFX skin itself and everything else has been commented out.
    / Toggle the Auto Pause of Winamp On and Off when iGuidance Speaks
    "AUTOPauseON","SETVAR;pauseonvoice;1||SAVETOINI;pa useonvoice;1||SETIND;!AutoPauseOn;ON||SETIND;!Auto PauseOff;OFF"
    "AUTOPauseOff","SETVAR;pauseonvoice;0||SAVETOINI;p auseonvoice;0||SETIND;!AutoPauseOn;OFF||SETIND;!Au toPauseOff;ON"
    Still for the music to go all the way down to 0 the IG volume should be set to 4 out of the 5 lines in the IG volume menu for the music volume reduce to work.
  4. #14
    Jun 2002
    Virginia
    Thanks to Sonic, it appears that we're starting to nail down this issue. I found two exectbl.ini files, one in the Road Runner folder and the other in the DigitalFX folder. The one in the Road Runner folder was created by RRConfig. That tells me there must be some sort of conflict going on between the new Config and DigitalFX. I deleted the exectbl.ini in the RoadRunner folder and the music volume is now lowering when iGuidance speaks, but it is not pausing. I can live with that because at least now I can hear the iGuidance directions; however, I prefer pausing. FWIW, screen switching is working just fine. Maybe Blue and JohnWPB can get together and figure out how to eliminate this issue.
  5. #15
    Jun 2002
    Virginia
    Quote Originally Posted by TonyWare View Post
    Tony, I'm a little confused by this statement. Are you getting the music to actually pause or just reduce to zero volume?
  6. #16
    Jun 2007
    Ottawa Canada
    Quote Originally Posted by kbreeden View Post
    I am not sure what it does. I think the volume goes to 0 since the song keeps playing in the background. I mean when it resumes it skips a few seconds, so I assume the volume goes down but the song doesn't pause. "Waiting for GPS signal" is what? 3 seconds? I'll look into it a bit more when I drive to work tomorrow.
    (now port 9 on iG doesn't work as before... more config lines I guess?)
  7. #17
    Oct 2005
    hmmm.....I'm having the same problem as well
  8. #18
    Jun 2007
    St. Louis
    k... re-installed EVERYTHING. From the ground up. Now it works...after I swore it off and decided to give up and just go to bed.
    Here's how my config is setup:
    Master Volume - 100%
    Wave Volume - ~60%
    WinAmp Volume - 100%
    iG Volume - 100%
    Using RR 9-30. RRConfig 10-10. DigitalFX 2.5.
    When I setup RR, the I left the "lower volume" checkbox in the GPS section UNCHECKED.
    I checked IGNative. Inside the iGnative options, I set the left 3 checkboxes to checked. Exited.
    Went back into RRconfig and it said I have the Pause feature enabled with no custom commands and that I could set Winamp to lower the volume instead of pause (YES or NO). I clicked YES.
    Now it all works. It ONLY worked when I dropped the WAVE volume down to the third mark from the top with everything else at 100%. Now when iGlady speaks, the volume is lowered quite nicely.
    hope that info helps. Doubt you need a full re-install to resolve it, but I did since I had a number of funny things going on with the setup. Now all I need to do is get HORM working and I'll be a happy camper
  9. #19
    Woodbridge, VA
    Blog Entries
    32
    i'm willing to bet there's a setting in your rr.ini thats setting the volume and not pausing by default. As i said before, the new rrconfig asks if u wish to set it up that way once. Perhaps you did.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. Music Indexing
    By aforget in forum StreetDeck
    Last Post: 02-06-2007, 11:25 AM
  3. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 10:08 PM
