Results 1 to 10 of 19
Thread: Has Anyone Using RR/DigitalFX/New RRConfig/iG4 Gotten Music to Pause?
    Jun 2002
    Virginia
    I've posted this question in the bodies of a couple of threads, but nobody has answered. Hopefully, it will get more attention in its own thread.
    A few of us who are using the combination of newest RR, newest RRConfig, newest DigitalFX and iG4 are unable to get music to pause when iG is saying directions. It worked flawlessly for me with the previous versions of all of those.
    So the question is: Has anybody using that combination been able to make music pause when iG is saying directions?
    If so, I sure would be interested in seeing your RRConfig settings and rr.ini entries.
    Jun 2007
    St. Louis
    I haven't been able to get that function to work either. Haven't even gotten it to simply lower the volume. This is quite annoying though. As a way around it, I have set my wave volume to around 80% and the IG volume all the way up. This way at least the IG voice is slightly louder than music. Downside to this though is I have to turn up the volume twice as much as compared to the factory radio/cd. If I leave all the volumes at max, then the factory radio/cd volume matches the carpc volume...but then you can't hear the IG directions very well.
    catch 22 right now.
    I'd be interested in a fix as well. Tried everything I've seen in threads to get it to work, but nothing seems to work. Going to re-install everything this morning though.
    Jun 2002
    Virginia
    Quote Originally Posted by nst6563 View Post
    catch 22 right now.
    Thanks, nst. Please let us know if reinstall is successful.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    pauses for me just fine.. it pauses the same way in every skin just fine using the new config
    Live mp3Car Facebook Chat
    Jun 2002
    Virginia
    Quote Originally Posted by Sonicxtacy02 View Post
    Thanks, Sonic. I know you use your own skin, though, and am curious whether you've done it in DigitalFX.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    I have it working fine in DigitalFX
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Woodbridge, VA
    Blog Entries
    32
    the feature is really skin-independent.. its something thats set up for you in the new rrConfig. if the config detects you're using ignative and have pauseonvoice enabled... it will as you if u'd rather lower the volume. If you hit yes it works no matter what skin you use.
    Low Bitrate TonyWare's Avatar
    Jun 2007
    Ottawa Canada
    Perhaps someone can re-create this.
    Go to config, GPS and check the iG Native. The name of the window is iGuidance and the external radio-style button is set. The check button to reduce the volume is set and its at 10%. So now the IG Native panel (in the tree under GPS) is enabled so go in there and check all the checkmark-style buttons (the 2 auto switch and the pause). Save and exit.
    Start RR with DFX (both latest and greatest). Start music, go to gps screen, make IG say something, whatever. Go back to main menu, exit application.
    Go back to config and see if the 2 autoswitch checkmark-style and the auto pause are checked in the iGNative panel under GPS. Mine were unchecked even though I checked them when I setup using the config.
    Perhaps these steps will give some clues to the folks who know the source code inside out.
    Jun 2002
    Virginia
    Sonic, I know that is supposed to be the case; however, n DigitalFX, volume will not pause or lower no matter what I do. I have spent hours trying to figure it out. It worked flawlessly for me until I loaded the new versons. DigitalFX does have an iGuidance autoconfig screen so there is some possibility for conflict, though I assume all the autoconfig does is put the appropriate lines in rr.ini.
    Jun 2002
    Virginia
    Quote Originally Posted by TonyWare View Post
    I have experienced similar results.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. Music Indexing
    By aforget in forum StreetDeck
    Last Post: 02-06-2007, 11:25 AM
  3. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 10:08 PM
