Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: many Q's with config-blue zx3
  1. #11
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    dude. any help you 'd like we r here for you.
    sorry to hear about your accident..
    RR is a great hobby by itself..and learning is part of the fun.
  2. #12
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Sorry to also hear about the past. Glad to see another new RR user, because of all the awesome options this software offers, it also means that new users are often perplexed to the what's and how's. Knowing that RR can be a pain to set up, and still deciding to go for it, with the added fact, shows that you are headed towards a great RR expereince!
    I have done a LOT of work on that config, and it's just like RR, it will never be done!!
    One of my things To-Do is to make a help button on each tab that hopefully better describes what each option is or does ( haven't even started on it yet) so that users such as your self can set each setting to what they believe is the best choice for their setup.
    Now for some answers:
    4. leave mouse alone....what exactly does it do? if the hide mouse is checked, then how and what does checking this one do?
    Even with the mouse hidden, sometimes effect different things, I beleive that these are mostly skin type issues. This setting has 3 settings, True, false, never. True= tells rr to not move the mouse when you click on a button in a skin that takes you to another screen, false is just oppsite of true, means that rr will move the mouse back to the bottom left cornner on every button click, and never tells rr to never ever move the mouse( the mouse will only move when the user command it to )
    6. screen fastmode....what does this one do? looks like GDI+ is the defualt
    [color="Red"]this depends on the skin if its tranparent skin set to GDI+[color="Red"]
    GDI+ is needed for needed for any of the transpartent skins. Depending on your hardware setup, using the GDI+ setting also alow's quicker screen changes, but if you not using a transparent skin, an have a very low end system, then one of the other options might be better for you. Also looks like there might be a small bug that showed up.
    7. soundcard # 0......is that just for the software location or however thats explained? i have the mp915 with integrated sound if that helps any
    this for external cards i think <--
    This setting is almost always set to 0, unless you have two or more sound cards installed in your setup. If you did, it tells rr which card you want to use.
    8. screen-limit: 3-min.....kinda self explanitory for the 3 minutes part, but hearing a better explanation will help a lot
    This setting only depends on your hardware once again, it was added because some video cards start having issues when there is too much video being used to cache the screens, so this setting limits the amount of screens that rr will keep in the cache, rotating least used screen first, before loading the new one. But also using the 3-min also means that if you change between more than 3 screens than the time to load each screen will not be as fast as upping it to say like 10. I have been using '0' for a while w/o probs(<--knocks on wood) which never deletes the loaded skin from memory.
    the amount of screens cached in the memory set to 3 min works well
    minimum yes, best setting no
    9. ipod drive: .........i dont ever plan on using a ipod with my carputer, seems kinda dumb to me. but i see choices for a drive letter to choose. why would u need to assign a drive letter? i dont have a ipod, so that sorta confuses me.
    leave it as defaulted
    Explained a little more(FYI): this is for user that wish to keep a smaller collection of music in their car and want to play what the have on their ipod. The drive letter would be so that rr would know where to look if it set to anything other than default, as when you plug in an ipod it shows up just like another drive on your comp. (<-- doesn't own one now and doesn't plan on it anytime in the far futre either.)
    10. song intro / station scan (in seconds).........kinda self explanitory, but how does it get the song or station?
    This is just like the setting on most portable cd players, where it plays the first x seconds from each track until you turn off the setting. ( Never used it then either)
    11. map master volume to control line (for pu$$y @ss soundcards)........does this one really matter? does RR affect a soundcard already turned up 75%? (its going to be a amped signal)
    this controls the levels in your sound propertys matser vol + main vol, wave + wave vol and so on
    I pretty sure that it's not quite worded like that in the config...
    16. gamma......is that tab for messing with display settings affecting only the RR skin?
    Close, it only takes effect while rr is running, you close rr durring a time when the night gamma is set and you might be momentairly blinded b/c the screen will be set back to its original bright settings.
    17. id3 tags.....there are different versions of id3 tags?
    most people use id3 tags i have mine set to mix v1 with v2
    Yes, there are differnt versions of ID3 tags, the v1 only stared to list basic things like artist,album, ect. The v2 contains a lot more information as it get more popular, people wanted to be able to attatch more info about each song to the song.
    18. vis plugins....those look to be wmp only kind.
    winamp also plays visualtions, milkdrop,and avs vis.
    Sorta, depends on which backend player you are using, WA is the default player that rr uses and there are doz of different one that you could use, but the two that are list both come with the basic install of winamp and are the stablest ones to use in rr.
    19. scroll mode....to scroll what? im gonna overdrive my few remaing brain cellls guess that is doing something with text.
    text in the skins most people leave this i think
    Save those cell until you really need them later when you want to add or change something in a skin. The text in some areas do not fit the area designed to display them, so this option sets how the label will move in order to show all of the text that is in that label, example would be the current track name playing, in most skins it scroll the left.
    20. speed att volume......is there a rig that uses signal from the vss/ecm like my delco does?
    No, this uses the speed from the GPS, if you have any setup, it works really good once you get it setup to your likeness.
    So I hope that helps you out some more and any other new users confused by all these great features that all of RR's contributers( myself included) out.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #13
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by MGD View Post
    You better off buying StreetDeck. If you have that many question and don't understand them then you will have no fun with your car PC.
    WRONG, WRONG! Case and point, Time:about 3yrs back, came upon this great and fun hobby. Saw people using little scripts(AutoIt) to do things that the main software(RR) either couldn't do or didn't do at the time and opened up one and swore that it looked chineese to me and thought that it'd be cool to know how to do that stuff one day...Time: current day and time. I have since devoped countless apps.
    Some for a added feature in rr including this very config that is now the default RR config which w/o plugging it too much, is the grandest config that RR has ever been setup with PERIOD!
    It just depends on one's own curiosity and drive to learn something new. I did some programming in basic many a moons ago..Vic20/Commador64 <-- still have sitting in basement!
    LOL
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #14
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well i did'nt do
    to badly then lol...
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  5. #15
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    nope, you helped get him started..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #16
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    many thanx to all of you again. yes that accident was terrible. from all the therepys im having to go through and all the scars i have now im glad to not remember any of it.
    i was messing with RR on vista last nite, and i found out RR does not work that well on vista. glad my car pc has xp its a legal copy:P ive been messing with RR in my laptop here at work. and my laptop has vista. cant go back to xp on my model at all. ya, that really sux. but oh well
  7. #17
    Apr 2007
    Edmond, Ok
    ok, i just read through is all. and zx3.....i never would have thought the zx3 in the config name would be you! haha goes to show mow much i havent been on this group!
  8. #18
    Apr 2007
    Edmond, Ok
    heres one i forgot to add...its under skins
    background path?
  9. #19
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by americasfuture2 View Post
    ..... i like learning what this stuff is and how to tweak/tune it. i had an accident a yr ago and suffered severe brain damage and lost a lot of my memory. im doing what i can to get back to where i was in my life. and i do need lots of peoples help on things that i just can not remember how to do that i used to mess with a lot. its sad really. NEVER FOLLOW IN MY FOOTSTEPS AND STREETRACE AT REDICULOUS SPEEDS!!! i lost control of my vette racing from what i was told and dam near ruined my life.
    Good to hear you're doing fine. I also had an accident couple yrs. back on my Gixxer 1000 doing almost the same thing. Suffered severly, but came back strong. Then I stumbled onto this site looking for info on headrest monitors. Now im building me a carputer. There is a wealth of knowledge on this site, and the guys on this forum are (for the most part) pretty good at answering questions from us noobs. Some will even answer the same exact question over and over without a hint of sarcasm. Great forum, great guys, and they produce great work (ie. Guino,JohnWPB,LS,Blue,chuck) just to name a few. So if you have questions comments or concerns post away bro. 'cause i think these guys got your back.
    Quote Originally Posted by -zip- View Post
    Man sorry to hear that. This is an excellent oppurtunity to get that brain power stronger!
    Yeah man, Got that right
    If you cant DODGE em, RAM em.
  10. #20
    Apr 2007
    Edmond, Ok
    mmm nachos......:P
  1. RR Config Updated - Blue ZX3
    By Blue ZX3 in forum Road Runner
    Last Post: 06-09-2011, 04:17 PM
  2. Replies: 4
    Last Post: 12-27-2006, 03:22 PM
  3. ****Celica Carbon Fiber Car Computer Finished****
    By hombredelassrta in forum Show off your project
    Last Post: 09-02-2006, 02:22 PM
  4. BLUE SCREEN on my MONITOR!! WHATS THAT MEAN???
    By ironic in forum General Hardware Discussion
    Last Post: 08-05-2006, 02:24 PM
  5. Store keypress config? and remote config troubles.
    By lilmansplace in forum Media Engine
    Last Post: 04-08-2005, 05:07 PM
