Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: many Q's with config-blue zx3
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    i have never been good with this kind of stuff, software wise.
    i did not see any tutorials for the config besides the one that came with it. didnt explain well enough to me tho
    1. for the INI path....what is that?
    2. launch path.......to launch what? a custom app?
    3. start command(s)......what exactly is this? i was thinking it was for the computer booting up. but in the read me it says it will execute the commans (I.E. AUDIO etc) after starting software. shouldnt it already start that? or does this need to be told how to turn audio on?
    4. leave mouse alone....what exactly does it do? if the hide mouse is checked, then how and what does checking this one do?
    5. disable SAPI 5 and use SAPI 4.......no idea what that is. so i dont know what to ask for that one haha
    6. screen fastmode....what does this one do? looks like GDI+ is the defualt
    7. soundcard # 0......is that just for the software location or however thats explained? i have the mp915 with integrated sound if that helps any
    8. screen-limit: 3-min.....kinda self explanitory for the 3 minutes part, but hearing a better explanation will help a lot
    9. ipod drive: .........i dont ever plan on using a ipod with my carputer, seems kinda dumb to me. but i see choices for a drive letter to choose. why would u need to assign a drive letter? i dont have a ipod, so that sorta confuses me.
    10. song intro / station scan (in seconds).........kinda self explanitory, but how does it get the song or station?
    11. map master volume to control line (for pu$$y @ss soundcards)........does this one really matter? does RR affect a soundcard already turned up 75%? (its going to be a amped signal)
    12. web browser: ()firefox ()internet explorer path: .........is that for an alternate browser?
    13. misc other settings..........use built-in voice control.........built in to what? RR or the soundcard software?
    14. use car2pc interface.........havent looked into that, so skip!
    15. skin paths: day path, night path......... is the night one triggered by the illumination signal comming in from the dash illumination signal? (GM Orange wire if i remember correctly on my old GM's)
    16. gamma......is that tab for messing with display settings affecting only the RR skin?
    17. id3 tags.....there are different versions of id3 tags?
    18. vis plugins....those look to be wmp only kind.
    19. scroll mode....to scroll what? im gonna overdrive my few remaing brain cellls guess that is doing something with text.
    20. speed att volume......is there a rig that uses signal from the vss/ecm like my delco does?
    21. fone control.......is all this for using ur carpc as your fone too? ive got the cingy 8125, aka the HTC wizrd if that helps for anything i can do
    well thats all i have for now. anything that i didnt ask about is either because its simple enough to figure out or it is a option i do not have yet.
    i have mainly been focusing on my hardware setup. never was good with software.
    now that RR itself just popped up, its the default skin. is there a way to change the
    car: N/A
    out: N/A.....not sure what it means by out.
    i thank all of you in advance for the help with this. i have seen many times that this one is a ****** to use. im finding that out! haha. this should also help any newbies later on. if i have any other Q's involving the skinning or other functions there are catagories for, they will be post in the appropriate ones. Again, thank all of you.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by americasfuture2 View Post
    don't worry about it
    direct this to your launch folder which is in the Road Runner folder
    some plugin's and other app's sometimes need to be started when Road runner starts
    this 1 puzzeled me to
    changes the text to speach format depends on what version you are using
    [COLOR="Red"]this depends on the skin if its tranparent skin set to GDI+[COLOR="Red"]
    this for external cards i think
    the amount of screens cached in the memory set to 3 min works well
    leave it as defaulted
    this controls the levvels in your sound propertys matser vol + main vol, wave + wave vol and so on
    fire fox is a better internet browser thats all, downloadable from Morzilla
    built into RR
    no this is set by time, 2 skins needed to be loaded some skins come with night and day skin
    most people use id3 tags i have mine set to mix v1 with v2
    winamp also plays visualtions, milkdrop,and avs vis.
    text in the skins most people leave this i think
    this is for a app called phonecontrol downloadable from yhte net
    car: N/A
    these are for tempature i think separate software and hardware
    this is the best i can do, if i'm wrong or someone may answer the 1's i missed
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    dude check the "readme.txt" in RR's path..everything is explained there (almost)
    Apr 2007
    Edmond, Ok
    i checked, didnt really make sense to me. im simple when it comes to software on the programming side.
    Apr 2007
    Edmond, Ok
    great help carpputer1!
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You better off buying StreetDeck. If you have that many question and don't understand them then you will have no fun with your car PC.
    Apr 2006
    Greece
    Quote Originally Posted by MGD View Post
    maaaan you r scaring away customers!!!
    Apr 2007
    Edmond, Ok
    im too cheap for street deck. navy doesnt pay me that well. i like learning what this stuff is and how to tweak/tune it. i had an accident a yr ago and suffered severe brain damage and lost a lot of my memory. im doing what i can to get back to where i was in my life. and i do need lots of peoples help on things that i just can not remember how to do that i used to mess with a lot. its sad really. NEVER FOLLOW IN MY FOOTSTEPS AND STREETRACE AT REDICULOUS SPEEDS!!! i lost control of my vette racing from what i was told and dam near ruined my life.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Man sorry to hear that. This is an excellent oppurtunity to get that brain power stronger!
    Sound Stage
    Eclipse|MTX|Infinity
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    Fixed it for you
    I admire your persistence to learn this stuff, good luck.
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
  1. RR Config Updated - Blue ZX3
    By Blue ZX3 in forum Road Runner
    Last Post: 06-09-2011, 04:17 PM
  2. Replies: 4
    Last Post: 12-27-2006, 03:22 PM
  3. ****Celica Carbon Fiber Car Computer Finished****
    By hombredelassrta in forum Show off your project
    Last Post: 09-02-2006, 02:22 PM
  4. BLUE SCREEN on my MONITOR!! WHATS THAT MEAN???
    By ironic in forum General Hardware Discussion
    Last Post: 08-05-2006, 02:24 PM
  5. Store keypress config? and remote config troubles.
    By lilmansplace in forum Media Engine
    Last Post: 04-08-2005, 05:07 PM
