Problem with RR (started with Digital FX) (Freezing, music still plays)
Working on my first install here, so I hope you will forgive me for lack of knowledge.
I am having a similar problem as BIGGKATT01 at the moment, where RR will simply freeze. This has occurred at different times and on different windows so far. Since the problem I am having seems broader than his, I am making a new thread, if the fix is the same, please feel free to beat me upside the head (;
Updated both RR and Digital FX to newest versions I've found. (Used RR's auto updater, and downloaded DFX)
Downgraded to Winamp 5.13 (to fix a problem with no audio using 5.5 when using DFX, 5.13 has worked like a charm)
Downloaded Flash (I may not have gone to www.adobe.com and done the flash install earlier)(this appears to have fixed the constant crashes when trying to change the skin color, but has not had any effect on the other crashes)
Checked both picspath and background path, they are both set to the skin's background's folder.
I will go check if it crashes at all on the default skin. It did not before (but I have made numerous changes attempting to get this skin to work). When it freezes, music will continue, but no input is accepted via the touchscreen. I can do a CTRL+ALT+DEL to open the task manager, kill RR (which seems to end Winamp as well, since music cuts out here), and restart RR with no problems.
If I am missing any obvious solutions (or a help file that discusses this issue) I apologize and would appreciate a pointer in the right direction.
(Update: freeze is happening in default skin as well, and out of 2 freezes, one time win amp kept playing after CTRL+ALT+DEL, second time winamp stopped playing, but all icons on the desktop were hidden/missing, and mouse cursor was not visible (though I could still click with the mouse, if that makes sense))
