Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 40 of 107
Thread: RR 10-26-2007.. iLists & Custom stuff..
  1. #31
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by Sonicxtacy02 View Post
    The source code is the uncompiled version of rr.. it allows end-users to modify/add code to road runner.. the binary is the compiled source code with all other requirements. Unless you plan on modifying RR's code you want the binary.
    Thank you Sonic,
    Wanted to update RR and wasnt sure which one to dl.
    If you cant DODGE em, RAM em.
  2. #32
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I'm having problems displaying ID3 tags in a playlist with the new iList option.
    Greek characters are not show correctly and are shown like small squares. As soon as I comment out the IL command everything shows up correctly. If the playlist has English characters then the ilist function operates great.
    I'm using text mode for ilist, did not try bmp. mode yet.
    Any ideas ?
    Hey Nomader, did you get to display Greek characters with iList and what font are you using?
    Edit.
    Go it working by changing the font
    The road is long but we are getting there.
  3. #33
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by tolisn View Post
    I'm having problems displaying ID3 tags in a playlist with the new ilist option.
    Any ideas ?
    greek characters show PERFECTLY in both text and bitmap mode!!!! try another font maybe
    one more thing.. just tried it in the car..Ilists do not hibernate properly..after resume the lists are all empty..they work (if you click on a song it plays) but the do not show.. only the unse.bmp is there..
    a RELOADSKIN fixes it
  4. #34
    Constant Bitrate C4DAO's Avatar
    Apr 2007
    Cardiff
    Once again thanks Guino!
  5. #35
    Low Bitrate uptpilot's Avatar
    Jun 2005
    Oklahoma City
    Guino, I made a new page called Browser2.skin. According to your documentation:
    /, (S) Directory, Picture List
    /, FOREFILE FOREDIR SELECTED SELECT FONT
    /, x y w h r g b r g b r g b r g b trs pt font
    SXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XX X,XXX,XXX,XXX,XXX,TRUE,XX,"Arial Narrow:B"
    The above tag creates a directory/folder view within the given boundaries, with the selected colors/font.
    The picture list is the same format as a directory/folder list, and is only applicable to picviewer.skin
    Therefore, here is my resulting code:
    [HL]RoadRunner Skin
    RRScreen Browser2
    AUDIO_BROWSER2_DAY_OFF.jpg,AUDIO_BROWSER2_DAY_OFF. jpg,AUDIO_BROWSER2_DAY_ON.jpg,AUDIO_BROWSER2_DAY_O N.jpg
    /S,2,97,347,420,0,128,255,255,255,255,0,0,0,128,0,2 55,255,0,0,64,0,128,TRUE,14,"Arial"
    S02,66,161,663,354,255,255,255,000,000,000,255,245 ,000,255,255,255,255,255,0,0,0,0,TRUE,20,"Arial:B"
    B,671,517,66,86,"GPS",GPS
    B,734,514,75,91,"MENU;MENU.SKIN",Main Menu
    END[/HL]
    Why is it not showing a directory listing?
    Also, if I use the ILIST command, how does it exactly relate to the Directory Listing above? Am I correct to assume that if I have a Directory List, that making an ILIST reference then automatically modifies the Directory List object?
    Apr 2006
    Sydney, Australia
    Thanks for the update Guino!!
    New Car PC Build list in progress
  7. #37
    Apr 2006
    Greece
    Quote Originally Posted by uptpilot View Post
    [HL]RoadRunner Skin
    RRScreen Browser2
    END[/HL]
    ok here is an example:
    /, S, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
    S,159,142,570,379,0,255,0,0,0,0,0,255,0,0,255,0,0, 0,0,255,0,0,,24,"Century Gothic"
    IL,DL,unsel.bmp,sel.bmp,,1,20,70
    this transforms the standard list above (defined withe the "S") into an ilist. the characteristics of the list (color, font..etc) are defined with the "S"
    the "IL" definition just transforms the standard list into an ilist and defines 3 BMP's to use
    one for a background color, one for a selected item color, and one for the end item (when list reaches the end - i am not making use of the 3d bmp in the above example) plus the speed of scrolling etc..(as described on 1st post)
    THE ABOVE IS USONG BITMAP MODE
    Now if instead of the GREEN LINE above tyou use this:
    IL,DL,RGB000010,RGB00F000,************,1,20,70
    then you r using TEXT MODE. no BMP's are needed here, just define 2 SOLID colors (in HEX) and the rest of the values are the same(scrolling speed etc..)
    here are the SEL.BMP and the UNSEL.BMP i am using just to get you started, right click and save them into your skin folder
  8. #38
    Jun 2005
    Oklahoma City
    Guino,
    Would it be possible for RR to have a big center window animated wait icon? Sometimes RR takes a while to do things (e.g. change folder views while reading), and most users besides myself would keep pressing the touchscreen thinking that it didn't register their input.
    Thanks,
    UPTPILOT
  9. #39
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If your talking about folder views while browsing for audio, I', working on a RR Media DB plugin like WA's. So browsing should be much improved....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  10. #40
    Maximum Bitrate Dalailama's Avatar
    Jan 2006
    Novara Italy
    Hi guys,
    I've a problem with the ilist command...
    ...installed directx9, new rr version...
    ...tryed with PL, but when I open audio player it freezer RR
    ...is it possible that it's a problem of xp beast edition?
    Live today like it is your last day, and behave as though you will live forever...
    my WEBSITE
    MapMonkey Dalai skin-preview-download ITA-email me for ENG
    Road Runner CrystalBlue skin-preview-beta release
  1. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. RR 09-28-05... EQ stuff...
    By guino in forum Road Runner
    Last Post: 10-01-2005, 02:08 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
