RR 10-26-2007.. iLists & Custom stuff..
In this version:
-Added support for "iLists" (Requires at least DirectX 7)
-Added support for "Custom Lists" (SDK/Plugin/Scripting support)
-Added support for "Custom Sliders" (SDK/Plugin/Scripting support)
-Added command to show/hide labels as desired
-Added support to show Water Depth and Temperature for extended GPS devices
-Added support to poll track path of any item in the playlist (for SDK/Flash)
-Added alternate Resume Check for those with issues on hibernate/standby
-Added prevention against empty audiofiles/videofiles settings
-Improved PREV2 command to work like PREV when holding
-Improved event handling for Lists
-Fixed NEXTAVS/PREVAVS/FULLAVS commands not working on 9-30
-Fixed issue with coverart when switching from between certain screens
-Updated HD Radio Control
-Skin Editor V0.5 is also released:
http://www.mp3car.com/vbulletin/rr-s...or-v0-5-a.html
Notes:
-Wonder what iLists are ? Check it out HERE and HERE
-iLists require at least DirectX 7 -- it is shipped with anything above Windows 2000 and can be installed even in Win98SE. If you use Vista, you'll have to download DX7VB.DLL from the web.
-To take the maximun advantage of iLists: use only filenames (improves Playist and Dir list) OR use the read Metadata ON LOAD in winamp (improves playlist). Using tags will cause the iList to lag accordingly while reading TAGs.
-Custom lists are also limited on ONE per screen and can be made into iLists as well.
-Custom Sliders are unlimited but with pre-defined range (which can be converted using EVAL to almost any purpose).
-ResumeCheck is based on tejesh83's code (Thanks) from another thread. Just add resumecheck=true to RR.INI if you have problems resuming from hibernate.
-Everything else should be commented and you can find information either in Skin Commands.txt or Readme.txt.
-We've also enlisted some help from JohnWPB on the RR forum -- Welcome!
There's always more to come.. enjoy it for now,
Guino.
