Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 107
Thread: RR 10-26-2007.. iLists & Custom stuff..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 10-26-2007.. iLists & Custom stuff..
    In this version:
    -Added support for "iLists" (Requires at least DirectX 7)
    -Added support for "Custom Lists" (SDK/Plugin/Scripting support)
    -Added support for "Custom Sliders" (SDK/Plugin/Scripting support)
    -Added command to show/hide labels as desired
    -Added support to show Water Depth and Temperature for extended GPS devices
    -Added support to poll track path of any item in the playlist (for SDK/Flash)
    -Added alternate Resume Check for those with issues on hibernate/standby
    -Added prevention against empty audiofiles/videofiles settings
    -Improved PREV2 command to work like PREV when holding
    -Improved event handling for Lists
    -Fixed NEXTAVS/PREVAVS/FULLAVS commands not working on 9-30
    -Fixed issue with coverart when switching from between certain screens
    -Updated HD Radio Control
    -Skin Editor V0.5 is also released:
    http://www.mp3car.com/vbulletin/rr-s...or-v0-5-a.html
    Notes:
    -Wonder what iLists are ? Check it out HERE and HERE
    -iLists require at least DirectX 7 -- it is shipped with anything above Windows 2000 and can be installed even in Win98SE. If you use Vista, you'll have to download DX7VB.DLL from the web.
    -To take the maximun advantage of iLists: use only filenames (improves Playist and Dir list) OR use the read Metadata ON LOAD in winamp (improves playlist). Using tags will cause the iList to lag accordingly while reading TAGs.
    -Custom lists are also limited on ONE per screen and can be made into iLists as well.
    -Custom Sliders are unlimited but with pre-defined range (which can be converted using EVAL to almost any purpose).
    -ResumeCheck is based on tejesh83's code (Thanks) from another thread. Just add resumecheck=true to RR.INI if you have problems resuming from hibernate.
    -Everything else should be commented and you can find information either in Skin Commands.txt or Readme.txt.
    -We've also enlisted some help from JohnWPB on the RR forum -- Welcome!
    There's always more to come.. enjoy it for now,
    Guino.
    Ride Runner RR's Myspace
    Jun 2002
    Virginia
    Woohoo, I don't know what most of that stuff means, but thanks for all the hard work.
    Jan 2006
    Lexington, KY
    NICE!
    In addition to the free drink you now also get burger on me
    Constant Bitrate Tensai's Avatar
    Jun 2006
    Texas
    Guino, you and your work are amazing.
    Is it that it's fun? Or that it lets you forget yourself?
    May 2005
    Vienna, VA
    you're a machine.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Very Cool, and thanks for the kind Welcome!
    My Fiero Build Thread
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by guino View Post
    In this version:
    is this for items in the VISIBLE playlist or the entire playlist? Meaning in a 7 item displayed list if i'm scrolling a list will a be able to poll the track path for every list item i scroll to or just the initial 7 songs in line from the current track.
    If this works the way its intended to it would be HUGE for my upcoming skin.
    Live mp3Car Facebook Chat
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thanks for all the work...Customlists
    Just need to finish my "RR Media Db" plugin...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Sonicxtacy02 View Post
    Works with all Items in the playlist, regardless of them being in view or not -- note that this has nothing to do with the description for the items (which are normally loaded when in view).
  1. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. RR 09-28-05... EQ stuff...
    By guino in forum Road Runner
    Last Post: 10-01-2005, 02:08 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
