Results 1 to 9 of 9
Thread: GPS problems(streets and tips)
    Sep 2007
    Canada - Laval
    hi,
    i have a GPS that came with microsoft streets and tips (Pharos GPS-360)
    i installed Iguidance 4.0, all went ok, but when i try to navigate it stays in Waiting for gps signal.
    i folowed the FAQ on how to set Iguidance4.0 with RR, what can i do
    my gps is on COM3 and using Crystal Blue Beta skin
    thanks in advance
    Doc
    Dec 2006
    make sure you are outside when trying to get a signal. also, if this is the first time ever you start the gps receiver, sometimes, it can take up to 10 mins to get a signal.
    Low Bitrate dmart23's Avatar
    Oct 2007
    i agree, it take s a while for the signal, about 15-20 min, when you first use it. That was the case with my mio. after that it captures the signal really fast. Hope all goes well.
    Sep 2007
    Canada - Laval
    thanks you both,
    i will try it today after work and just leave it there for half an hour
    ill let you know what happend
    thanks gain
    Doc
    Dec 2005
    San Jose, Ca
    I know this is an old thread, but I am having a similar problem. I have the Pharos GPS-360 from MS streets and trips and I am trying to use it with Iguidance 4. The drivers are installed and windows says the device is working properly, but when I try to find the device in Iguidance I have no luck. It keeps telling me there is no GPS device found. Any ideas? I have the com port set to 5 and I have tried baud rates of 4800 and 9600. Thanks for the help!
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Actually the Microsoft GPS 360 (Re-branded Pharos GPS) is pretty robust. I usually get around 6-8 satellites with it hooked up to my PC here for testing. (single story home)
    Make sure you use the drivers that are on the Streets and Trips CD, as I have found that ones from MS or Pharos I couldn't get to work and was a royal pain! With the GPS plugged in, open system properties, hardware, device manager and expand the Com ports tree. Unplug the GPS and wait a couple seconds, and plug it in, noting what com port disappeared and reappeared. You now know for certain the com port to use in iGuidance. Just to get it up and running, Run iG stand alone, and not start Road Runner just to narrow down any conflicts, and make sure you can get it working. Then you can start using and setting up a com port splitter such as Xport.
    My Fiero Build Thread
    Dec 2006
    also, try setting the port to 1 with xport. mine was really picky for some reason
    Dec 2005
    San Jose, Ca
    Hey guys! So I ran Xport and set the receiver to port 2. I searched for devices in Iguidance and was able to find it on port 2 with a baud rate of 4800. however, its still not picking up any satellites. Everything is red in the satellite status screen. Any ideas? Is the receiver bad or is something? I waited for about 10 minutes with a direct sky view and still wasn't able to find any satellites. Thanks for all the help guys!
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by T_Blaze View Post
    I think S&T is OK but iGuidance needs a 1 digit COM port number. If you had it on say COM15 it would cut off the 2nd digit so it would be COM1 the next time.
